water supply engineer?or water treatment engineer?
42楼
water supply and drainage engineering
43楼
44楼
IF YOU INTRODUCE YOUR SPECIAL,HOW SHOULD YOU SAY .YOU SHOULD SAY :MY SPECIAL IS WATER SUPLYING AND WASTEWATER TREATING ENGINEERING
45楼
呵呵,大家不要争论,最简单的答案:
看看《给排水工程〉杂志,她的名称怎么翻译的!
46楼
water & waste water engineering
47楼
water and wastewater engineering
国外原版教材给出的,应该可信度较高吧。另外,我们自我介绍时都说自己在
water supply and drainage department
48楼
就是Water &Wastewater Engineering不要怀疑啦~~
49楼
我们用的是water supply and sewage
50楼
有这么复杂吗
51楼
its so much complex. this is my opinion: water supplyment and drainage engineering.
