water supply engineer?or water treatment engineer?
32楼
Plumbing and Drainage
偶经常投国外工程的标,香港kalloon station,爱尔兰CORK机场,都柏林机场,泰国SV GARDEN ...............,我想会是标准答案的。
33楼
Water supply and wastewater treatment engineering
34楼
正确的说法是: Water Water Water Water Water Water !!!呵呵
35楼
I fu le u.
36楼
Water supply and wastewater treatment engineering or waste waste waste waste waste :)
37楼
water supply and drainage engineering
38楼
问一下新华社,他是中国翻译的权威!说一就是一!
39楼
Water and Wastewater Engineering
40楼
I wonder why you are auguing so violently over the translation of a phrase that some of you even demonstrate what they are doing.as a matter of fact, it s up to everyone to make a proper choice if its understandable and in conformity with the common customs.all of your answers have been adopted by authoritative organizations and accepted by readers.take it easy!
41楼
偶的名片就是这么印刷的!
