个人收藏的IEC规范,无加密。随后会按照TC技术委员会,放出IEC规范。此部分规范为经过加密处理的,请先下载TBSInBrowser.rar,解压后安装,才可阅读。本人在瑞星和360环境下使用无任何问题,无毒无木马。下先放出两个分类。(TC1)名词术语 链接地址:150楼(TC2)旋转电机 链接地址:151楼继续(TC7)裸导体 链接地址:156楼(TC8)标准电压、额定电流值和频率:
个人收藏的IEC规范,无加密。
(TC1)名词术语 链接地址:150楼
(TC2)旋转电机 链接地址:151楼
继续
(TC7)裸导体 链接地址:
156楼
(TC8)标准电压、额定电流值和频率:163楼
(TC10)电工用绝缘流体:164楼
(TC34)灯及有关装置:
本帖最后由 quming100 于 2010-9-16 09:23 编辑 ]
42楼
IEC 60255-22-5 Electrical relays - Electrical disturbance tests for measuring relays and protecti
43楼
IEC 60255-23 Electrical Relays - Contact Performance
44楼
IEC 60255-24 Electrical relays - Common format for transient data exchange (COMTRADE) for power s
45楼
IEC 60269-1 Low-voltage fuses - General requirements
46楼
IEC 60269-2-1 Low-voltage fuses - Supplemetary Requirements for Fuses for use by authorized perso
47楼
谢谢楼主提供IEC规范:handshake
48楼
IEC 60269-2 Low-voltage fuses - Supplementary requirements for fuses for use by authorized person
49楼
IEC 60269-4-1 Low-voltage fuses - Supplementary requirements for fuse-links for the protection of
50楼
IEC 60269-4 Low-voltage fuses - Supplementary requirements for fuse-links for the protection of s
51楼
IEC 60298 A.C. metal-enclosed switchgear and controlgear for rated voltages above 1 kV and up to
