软土地基上分期施工的路堤沉降预测方法(英文文献及译文)
zpywy
zpywy Lv.12
2009年03月02日 00:45:50
来自于铁路工程
朊土地基上分期施工的路堤沉降预测方法(中英文对照版)DOC格式WORD文档大小:125KB注:无需解压密码朊土地基上分期施工的路堤沉降预测方法摘要:沉降量和沉降速率控制是软土地基上路堤工程设计的关键问题,由于固结理论的局限性和参数的不确定性,理论预测的精度较低,而基于现场实测数据的观测法则显示出了较高的精度。本文在Asaoka观测法的基础上,形成了一种软土路基上分期施工时路堤沉降预测的方法,结合江苏海相软土上的高速公路工程进行了沉降预测分析。
DOC格式 WORD文档
大小: 125KB
注:无需解压密码
朊土地基上分期施工的路堤沉降预测方法
关键词:沉降, 路堤, 观测法, 分期施工, 江苏海相软土
Settlement prediction of embankment s with stage
construction on soft ground
LIU Song-yu(Institute of Geotechnical Engineering, Southeast University,Nanjing 210096,China)
JING Fei(Institute of Geotechnical Engineering, Southeast University,Nanjing 210096,China)
Abstract: The magnitude and rate of the settlement are the key elements subjected to design analysis of embankments on soft ground. The observational
Institute of Geotechnical Engineering,Southeast University,Nanjing210096,China
methods based onfield measurement have indicated the promising results and become effective methods to predict the final settlement, while the uncertainties of parameters and theories limit significantly the accuracy of settlement estimation. This paper presents an observational method to predict the settlement performance of embankments with stage construction on soft ground based on Asaoka method. The case studies show the accordance of the predicting results with the field measured data. It is also given from the case study that the value of Eu / Cu ratio ranges from 50 to 100 for Jiangsu Marine clay and its actual coefficient of consolidation is almost one order of magnitude larger than the laboratory data.
Key words: settlement, embankment, observational method, stage construction, Jiangsu Marine clay
b3343a5e124ab79271b6.rar
30.7 KB
立即下载
免费打赏
ysl5229221
2010年05月03日 16:58:32
12楼
very good:victory:
zhangjjll2009
2010年05月19日 17:03:38
13楼
下载来看看,谢谢!
yegenguo
2010年05月27日 14:43:41
14楼
谢了楼主
yangziyun0731
2010年06月04日 08:30:58
15楼
我一直对软基换填和承载力有疑惑,我发了贴,但是对这方面的解释都不够, 迷茫中
yuesong573787891
2011年02月25日 16:54:36
16楼
谢谢,很好用
wxf_wh
2011年03月29日 11:20:59
17楼
very good
giveyoulife
2011年04月17日 11:01:55
18楼
下了支持下楼主
