摘 要 本设计为某商住楼建筑给水排水设计。本建筑为新建一栋25层的商住楼,建筑高78.80米,各层设置情况详见建筑分层平面图。地下室内为库房、电梯井、设备房(包括水泵房)和贮水池,地上一层、二层为营业厅,三层~二十五层为为住宅。负一层层高3.00m,地上一层层高3.00m,二层层高3.00m,三层~二十五层层高均为3.00m。室内、外地坪高差0.10m。 建筑物每层均设有卫生间,卫生间内有座便器、小便器、洗手盆等
本设计包括给水系统、排水系统、雨水系统、消防系统
给水系统采用分区供水,其中一至五层层为市政直接供水,六至二十五层分成二个区:6至16层为中区,17至25层为高区。
排水系统采用污废分流制。分为污水排水系统,废水排水系统和雨水排水系统。污水立管为满足排水要求均需设置专用排水立管。地下室不能采用重力流直接排出的的废水,排至地下室集水坑内,用潜水泵抽水至市政排水管网。
消防系统包括:室内消火栓系统、室外消火栓系统、自动喷淋系统系统。消火栓给水系统和自动喷淋灭火系统单独设置,自成体系,由专门水泵抽水供给。室内消火栓给水系统采用临时高压消防给水系统。屋顶设置18m3高位消防水箱.自动喷淋系统采用湿式喷水灭火系统。
关键词:给水 排水 消防
Abstract
The design for the commercial and residential building water supply anddrainage design. The new building is a 25 floor building, building 78.80 metershigh, each layer is provided details of building floor plan. The basement forthe storehouse, elevator, equipment room (including the pump house) and a waterstorage tank, ground floor, two layer is the business hall, three ~ twenty-fivefor residential. Negative a layer of high 3.00m, on a layer of high 3.00m, high3.00m two layers, three layers and twenty-five layers high are 3.00m. Indoor,field turf height 0.10m.
Building on each floor are equipped with bathroom, bathroom has atoilet, wash basin, urinal,
The design includes the water supply system, drainage system, rain watersystem, fire fighting system
Water-supply system partition, one to five layers of municipal watersupply, six to twenty-five layer is divided into two areas: 6 to 16 layers forcentral, 17 to 25 layers for high.
Drainage system using sewage waste diversion system. Divided into thesewage drainage system, waste water drainage and rainwater drainage system.Sewage pipe to meet engineering requirements are required to set up specialdrainage riser. The basement can not be used in gravity flow directlydischarged waste water, exhaust to the basement sump, with submersible pump tothe municipal drainage pipe network.
Fire protection system includes: thesystem of indoor fire hydrant system, fire hydrant system, automatic sprinklersystem. Fire hydrant system and automatic sprinkler system separate,self-contained, designed by pumping water supply. Fire hydrant water supplysystem of the temporary high pressure fire water supply system. Set the 18m3high roof fire water tank. Automatic sprinkler system using wet sprinklersystem.
Keywords: water supply and drainage andfire
目录
第一章 绪 论 1.1 建筑概况
建筑物每层均设有卫生间,卫生间内有座便器、小便器、洗手盆等。
1.2 设计任务与内容
要求设计建筑给水排水工程与土建工程配套,具体项目为:
1. 建筑给水工程
2. 建筑消防工程
3. 建筑排水工程
1.3 设计依据
1. 《建筑给排水设计规范》GB50016-2003
2. 《高层民用建筑设计防火规范》GB50045-95 (2005版)
3. 《自动喷水灭火设计规范》GB50084—2005
4. 《给排水设计手册》(第1.2.10.11分册)
5. 《建筑给水排水工程设计计算》(李玉华、苏德俭主编)
6. 《建筑给水排水工程》(第五版)中国建筑工业出版社
7. 《室外给水设计规范》GB50013-2006
8. 《室外排水设计规范》GB50014-2006
9. 《给水排水制图标准》 GB/T 50106-2001
10. 《建筑灭火器配置验收及检查规范》GB50444-2008
11. 《建筑设计防火规范》GB50116-2006
12. 《钢筋混凝土化粪池》 03S702
1.4 原始资料
1.4.1 图纸资料1:100
1. 地下室平面图
2. 首层平面图
3. 二层平面图
4. 标准层平面图
5. 顶层平面图等
1.4.2 文字资料
(一)建筑设计资料
(二)城市给水排水设计资料
建筑物西、南侧各有1根DN400的市政给水干管,管顶埋深为1.0m,常年提供的资用水头为0.35MPa。市政给水干管不允许直接抽水。市政排水管位于建筑物的南侧,污水排水管1根,管径为DN500,管顶埋深为1.6m;雨水排水管1根,管径为DN800,管顶埋深为2.1m。
第二章 设计方案拟定 2.1工程概况
本建筑为25层综合楼,楼高78.80m,属一类高层建筑。总占地面积1600m2,该建筑防火等级分类为一类。
地下一层设有集水井,发电机房,掩蔽室和库房等。地下一层下室内为库房、电梯井、设备房(包括水泵房)和贮水池。地上层主要为商住楼。楼房的中部设有二部电梯,一部消防电梯,一部民用。
2.2室内给水系统说明
2.2.1设计依 据:
1. 《给水排水设计手册》第一、二、十二册(第二版)
2. 《高层建筑给水排水设计》(李玉华、张爱民主编)
3. 《建筑给排水设计规范》GB50015-2006
4. 《建筑给水排水工程》(王增长主编)
5.《高层民用建筑设计防火规范》GB50045-95(2005年版)
6.《住宅建筑规范》GB50368-2005
7.《自动喷水灭火系统设计规范》GB50084-2001(2005年版)
8.《建筑灭火器配置设计规范》GBJ140-90(2005年版)
2.2.2方案选择
2.2.2.1给水分区
室外市政管网常年工作压力为0.30MPa(30m水柱),按下式粗略估算室内所需压力:
H=12+(n-2)×4 (n≥2) 公式(2—1)
式中: H —— 室内所需压力,米水柱
n —— 层数
经计算室外市政管网压力可供至三楼但由于一至五层层高较高所以为了供水安全一层至五层由市政供水。
因此,一层至五层采用市政管网直接供水。六层及六层以上给水系统分为两个区。
低区:1层—5层
中区:6层—15层;
高区:16层—25层;
2.2.2.2方案确定
1,确定二套给水方案:
方案A:地上1-5层由市政压力直接供水,其余部分采用屋顶水箱沿立管减压给水方式,水箱设于顶层.
方案B:地上1-5层由市政压力直接供水,其余部分均采用无负压供水,其生活水池设于地下一层,各区水泵也设于地下一层水泵间,集中管理。
2,方案分析和比较
⑴ 方案A的分析与讨论:
主要优点:
1.水泵数量少,选用一种型号即可,投资少。
2.在停电的情况下,屋顶水箱能够保证一定时间内的用水量。
主要缺点:
1.顶层水箱容积大,增加了建筑结构的荷载并且造成了水的再次污染。
2.起转输作用的管道管径较大,增加投资费用。
3.对减压阀要求较高,否则无法保证供水的安全可靠。
4.使用减压阀消耗多余能量,造成了能量的浪费。
各区共用水箱和部分管道,相互之间影响较大,降低了供水安全可靠性。
⑵方案B的分析与讨论:
主要优点:
1.水泵无负压供水,高效节能,当系统用水量减少时,水泵降低转速运行,根据相似定律,水泵的轴功率与转速的三次方成正比,转速下降时轴功率下降极大,所以变速调节流量在提高机械效率和减少能耗方面是显著的,该设备比一般设备节能10%到40%。
2.设备占地面积小,不设高位水箱,减少了建筑负荷,节省水箱占地面积。
3.避免了水质的二次污染。
4.并且较之减压阀供水投资小。
主要缺点:
1.需要一套价格较贵的气压罐及其自动控制设备,且维修复杂,维护费用较高。
2.由于不设置屋顶水箱,停电时无法保证住宅部分的用水。
从以上分析讨论来看,两个方案都有其可行性,具体结合到本建筑中,主要从经济技术角度考虑,倾向于采用方案B。由于昆明市用电系统安全可靠,一般不会出现断电的情况,可以保证住宅部分的用水。用水泵无负压供水从长远方面考虑可最大限度减少能耗而且供水水质和水量都有安全和保证。故决定采用方案B。
3,管网布置方式的确定
高层建筑给水管网布置和管网敷设的最基本原则是优质迅速,安全供水。
⑴ 上行下给式
该方式广泛用于各种高位水箱给水系统。这种给水系统的给水干管铺设于该分区的上部技术层或吊顶内,下连各给水立管向下供水,流向不变。如果主管高度较大,为了控制流量保证各用水点正常配水,在下部主管上或下部各支管上设置减压阀或减压孔板。
优点:与下行上给的供水方式相比较为最高层配水点流出水头稍高。
缺点:安装在吊顶内的配水干管可能因漏水或结露而损坏吊顶和墙面。
⑵ 下行上给式
该方式广泛用于气压水罐给水系统、无水箱给水系统以及市政直接给水系统。这些系统的给水干管多敷设于该区的下部技术层、室内管沟、地下室顶棚、或该分区底层下的吊顶内。
优点:减弱停泵水锤作用,明装时便于安装维修。
缺点:水的流向由下向上,水力条件差,最高层配水点流出水头较低。
根据以上各形式的优缺点以及其适用的系统类型,因此本设计一至四层布置成下行上给式。然而由于本系统的热水系统采取上行下给式,为了热水和冷水的出水水压相当因此在低区和高区的气压罐变频给水采取和热水相同的给水方式
综上所述,给水方式为地上1-5层由室外市政管网直接供水(采用下行上给式的给水方式,即城市管网→地上1-5楼各层卫生洁具),6~16层由底区水泵无负压供水(采用下行上给式的给水方式,即城市管网→水泵无负压→中区干管→6~16楼各层卫生洁具), 16~25层由高区变频泵供水(采用下行上给式的给水方式,即城市管网→水泵无负压→高区干管→16~25层各卫生洁具)。为了使各区最低卫生器或用水设备配水装置处的静水压力小于其工作压力(0.30~0.35MPa),商住楼卫生器具静水压力应小于0.45Mpa,以免配水装置的零件损坏漏水,静水压力超过0.45MPa,必须设减压设备。
2.3消防给水系统说明
2.3.1 设计依据
1. 《高层民用建筑设计防火规范》GB50045-95(2005年版)
2. 《自动喷水灭火系统设计规范》GB50084-2001(2005年版)
3. 《建筑设计防火规范》GB50016-2006
2.3.2 消火栓系统
本综合楼消防系统包括:室内、室外消火栓给水系统、自动喷淋灭火系统,消火栓给水系统和自动喷淋灭火系统单独设置,自成体系,由专门水泵抽水供给。
室内消火栓给水系统分为高压消防给水系统和临时高压消防给水系统。
高压消防给水系统当管网内常年保持着灭火需要的足够水量和水压,消防时不需要启动消防水泵的系统,为高压消防给水系统。这种系统不需要设置消防水箱。
临时高压给水系统管网内平时压力不高,消防时需要启动消防水泵,并且为及时扑救初期火灾,需要贮存10分钟消防水量的高位水箱(含整个建筑或分区系统的消防水箱)或气压罐或稳压泵等设备。这种系统为临时高压消防给水系统。
本建筑采用临时高压给水系统。方案分析:依据本建筑性质和规模,按照规定,在同一时间内只可能一处着火,故没必要分设高区、低区消防泵,设置稳压消火栓即可,而且这样设计可以减少泵的数量,维护管理方便,节约投资,充分利用了水箱的高度。
室内消防用水量根据建筑物属性(一类商住楼)应为40L/s,每根竖管最小流量为15 L/s,由于采用单出口消火栓,因此每枝水枪最小流量为5 L/s。同时应设检查和试验用的消火栓(屋顶消火栓),供本单位和消防队定期检验室内消火栓给水系统的供水能力时使用,而这对保护本建筑物免受邻近火灾的威胁有良好的效果。另外室外设水泵接合器,以便消防车接入,保证消防安全可靠。
室外消火栓给水系统围绕商住楼环形布置,消火栓位置距路边不宜大于2m,距建筑物外墙不宜小于5m,但不宜大于40m。水泵接合器距建筑物外墙不宜小于5m,其15m到40m范围内应设室外消火栓,以便配合使用。流量按一类建筑要求为30L/s,供水时间为3小时。每个室外消火栓用水量按10—15L/s计算。
根据我国目前的发展水平,高层建筑的消防用水量分别为室外消防用水量和室内消防用水量两部分,室外消防用水量主要供外围扑救。消防车取水并通过水泵接合器向室内供水或消防车直接进行补救,消防车从室外消火栓取水铺设水龙带,接出水枪,直接扑救建筑较低部分或临近建筑物的火灾,以防火灾蔓延。
消防水箱应储存10min 的消防用水量。高位消防水箱的消防储水量,根据规范一类公共建筑不应小于18m3;二类公共建筑和一类居住建筑不应小于12m3;二类居住建筑不应小于6.00m3。
2.3.3喷淋消防系统
1. 自动喷水灭火系统洒水系统的分类
(1)湿式喷水灭火系统
本系统适用于室温不低于4℃且不高于70℃的建筑物、构筑物内。
(2)干式喷水灭火系统和干湿式喷水灭火系统
干式喷水灭火系统适用与室温低于4℃ 或高于70℃ 的建筑物内。
(3)干、湿交替式自动喷水灭火系统
该系统适用于冬季可能冰冻但又无采暖设备的场所,因管道干湿交替,较易腐蚀.
(4)预作用喷水灭火系统
该系统适用于平时不许有水污渍的建筑物、构筑物内。
2.自动喷水灭火系统应有下列组件、配件和设施:
(1)应设有洒水喷头、水流指示器、报警阀组、压力开关等组件和末端试水装置,以及管道、供水设施;
(2) 控制管道静压的区段宜分区供水或设减压阀,控制管道动压的区段宜设减压孔板或节流管;
(3) 应设有泄水阀(或泄水口)、排气阀(或排气口)和排污口;
(4) 干式系统和预作用系统的配水管道应设快速排气阀。有压充气管道的快速排气阀入口前应设电动阀。
3. 自动喷水灭火系统的设计方案拟定
由《自动喷淋灭火系统设计规范》GB50084-2001(2005年版)可知,该综合楼地下一层属于中危险级2级,自动喷淋系统保护作用面积160m2,喷水强度8.0L/min
m2。1-2层为中危险1级,自动喷淋系统保护作用面积160m2,喷水强度6.0L/min
m2 。常年温度不低于4℃且不高于70℃,并结合适用条件和工程实际,故采用湿式喷水灭火系统。最不利点工作压力0.10Mpa。自动喷淋加压泵采用消防专用泵,一用一备。室外设有水泵接合器。
屋面消防专用水箱高度能满足最不利点喷头压力0.10Mpa的要求,不设置屋面喷淋稳压装置。除常规设置喷头保护部位外,在吊顶内净距大于800mm且有可燃物时均加设直立型喷头加以保护。吊顶处采用吊顶型喷头,无吊顶处采用直立型喷头,喷头动作温度采用68℃。
4. 自动喷水灭火系统的组成
(1)闭式喷头
闭式喷头是自动喷水灭火系统的关键。系统通过热敏释放的动作而自动喷水灭火。各部位喷头采用红色,公称动作温度68℃。
(2)配水管网
采用湿式喷水灭火系统,管网充水,管网采用树状,不用成环,每层配水管网首端安装阀门和水流指示器,管道末端设有压力表及试水阀门等。
(3)控制信号阀
当喷头自动喷水后,由控制信号自动送水和给消防控制中心报警信号。为了确保安全,还设有电动报警阀。
(4)吊顶和防晃装置
吊顶和支架的位置以不妨碍喷头效果为原则,一般吊架与喷头的距离大于0.3m,距末端喷头距离小于0.7m。
对电器设备的要求
①当喷头喷水,水流指示器、报警阀应报警至消防控制中心和消防泵房。
②水流指示器应能明显知道建筑中哪层、哪些喷头的动作。
③安装的感烟、感温、感光探测器能通过电器设施,自动装置进行报警。
④当最不利点压力降低于所需压力时,地下一层水泵自动启动,自动报警。
⑤两台喷淋消防泵应具有自动切换功能。当一台泵启动30秒后还不能达到消防要求时,另一台泵自动启动。
⑥延迟器安装于报警阀和水利警铃之间的信号管上,电器设备应有能防止水泵发生水锤时引起水利警铃的误动作。
2.4 室内排水系统说明
2.4.1 设计依据
1. 《给水排水设计手册》第二册(第二版)
3. 《建筑给水排水设计规范》GB 50015-2006
2.4.2 系统的分类
