这句话很多人都翻译不出来,难道真没有了牛人?
arlex7577
arlex7577 Lv.3
2004年09月05日 13:57:45
请那位专业人士做一个翻译成英文。谢谢逐段计算路灯电压损失非常繁琐,本文结合路灯负荷的特点,推导出适用于路灯及类似负荷的电压损失计算公式,结合工程实例来分析此公式,并得出结论。该结论对工程设计人员具有指导性的意义。
请那位专业人士做一个翻译成英文。谢谢
免费打赏
dajunh
2004年11月11日 12:40:14
12楼
As it is tedious to work out the voltage losses of the street lamps section by
section, this paper will find out a formula , from the performance of street lamp
burdens, to calculate the voltage losses and similar burdens. The formula will be
examined with the real cases found in the engineering projects and thus making a
conclusion which will be instructive to engineers in their project designs.
dajunh
2004年11月11日 12:41:16
13楼
I don’t know how to answer it
hrb-lwl
2004年11月13日 11:26:53
14楼
看不懂啊
lyhawk
2004年11月13日 11:31:16
15楼
不地道啊
还有些语法错误
不过还时不错
lyhawk
2004年11月13日 11:36:37
16楼
不地道啊
还有些语法错误
不过还时不错
chaowen
2004年11月13日 12:36:28
17楼
it‘s really tedious to calculate the voltage loss of street light section by
section. while, this article got a voltage loss formula that can be applied on street
light and similar charge by analyzing features of street light charge. it finally
reached a conclusion by putting this formula on real case. the conclusion can be a
meaningful guildline to designers.
好像差不多!!!!!!!!!!!!
scpxh
2004年11月14日 13:21:12
18楼
Calculate piecemeal losses of voltage of the street lamp are very tedious , this text combines the characteristic of the load of the street lamp , derive out voltage losses suitable for the street lamp and similar to loading and calculate formulae, combine the project instance to analyse this formula, draw the conclusion. This conclusion has guiding meanings to the project designer
c-g
2004年11月14日 14:50:50
19楼
好复杂
liuhua1990
2004年11月14日 15:39:39
20楼
如果你肯出重金,我可以帮你找一位翻译,肯定专业.
cccccc
2004年11月14日 20:44:58
21楼
Calculate piecemeal that losses of voltage of the street lamp are very tedious , this text combines the characteristic of the load of the street lamp , derive out voltage losses suitable for the street lamp and similar to loading and calculate formulae, combine the project instance to analyse this formula, and draw the conclusion. This conclusion has guiding meanings to the project designer.
这个更专业一点
