midas连续刚构桥模型的运行错误
yang2596
yang2596 Lv.2
2010年06月06日 09:59:36
来自于MIDAS
MULTI-FRONTAL SOLVERAVAILABLE MEMORY = 894.6 MBytesCONSTRUCTION STEP NO. : 1 / 14 STAGE NO : 1 STEP NO : 1ENTRY PHASE FOR RENUMBERINGENTRY NUMBERING_EQN ENTRY FORM_STIFF_MASS_LOAD THE INDIVIDUAL ELEMENT STIFFNESS AND LOAD MATRICES WILL NOW BE FORMED.
ENTRY NUMBERING_EQN
ELEMENT NO. : 784 OF 784
ENTRY SOLUTION PHASE
ENTRY LOAD_BLOCK
ENTRY ASSM_STIFF_LOAD ( FORM GLOBAL EQUILIBRIUM EQUATIONS IN BLOCKS )
ENTRY STATIC ANALYSIS FOR NONLINEAR. ITERATION NO. : 1
MULTI-FRONTAL SOLUTION HAS BEEN PERFORMED 10 % .
WARNING : NODE NO. 463 DZ DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 2211
WARNING : NODE NO. 58 RZ DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 6
WARNING : NODE NO. 467 RZ DOF HAS A SINGULAR DIAGONAL = 0.000
WARNING : EQUATION NO. 2238
WARNING : NODE NO. 467 RX DOF HAS A SINGULAR DIAGONAL = 0.000
WARNING : EQUATION NO. 2236
WARNING : NODE NO. 467 DZ DOF HAS A SINGULAR DIAGONAL = 0.000
WARNING : EQUATION NO. 2235
WARNING : NODE NO. 467 DY DOF HAS A SINGULAR DIAGONAL = 0.000
WARNING : EQUATION NO. 2234
WARNING : NODE NO. 467 RX DOF MAY BE SINGULAR.
WARNING : NODE NO. 68 DY DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 38
WARNING : NODE NO. 68 RX DOF MAY BE SINGULAR.
MULTI-FRONTAL SOLUTION HAS BEEN PERFORMED 20 % .
WARNING : NODE NO. 63 DZ DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 21
WARNING : NODE NO. 464 RZ DOF MAY BE SINGULAR.
MULTI-FRONTAL SOLUTION HAS BEEN COMPLETED.
DISPLACEMENT/FORCE/STRESS OUTPUT.
ELEM. : 784 OF 784
ENTRY STATIC ANALYSIS FOR NONLINEAR. ITERATION NO. : 2
DISPLACEMENT ERROR NORM .. : 0.00000E+00 CONVERGENCE TOLERANCE .. : 0.10000E-01
ELEM. : 784 OF 784
CONSTRUCTION STAGE RESULTS SAVED TO FN.CA6 FILE
CONSTRUCTION STEP NO. : 2 / 14 STAGE NO : 1 STEP NO : 2
ENTRY NUMBERING_EQN
ENTRY LOAD_BLOCK
ELEM. : 784 OF 784
DISPLACEMENT ERROR NORM .. : 0.10000E+01 CONVERGENCE TOLERANCE .. : 0.10000E-01
ELEM. : 784 OF 784
ENTRY STATIC ANALYSIS FOR NONLINEAR. ITERATION NO. : 3
ELEM. : 784 OF 784
CONSTRUCTION STEP NO. : 3 / 14 STAGE NO : 2 STEP NO : 1
ENTRY NUMBERING_EQN
ENTRY LOAD_BLOCK
WARNING : NODE NO. 48 DY DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 278
WARNING : NODE NO. 48 RZ DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 282
WARNING : NODE NO. 468 DY DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 2576
WARNING : NODE NO. 468 RX DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 2578
WARNING : EQUATION NO. 374
WARNING : NODE NO. 59 RZ DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 348
WARNING : NODE NO. 10 RZ DOF HAS A SINGULAR DIAGONAL = 0.000
WARNING : EQUATION NO. 60
WARNING : NODE NO. 10 RX DOF HAS A SINGULAR DIAGONAL = 0.000
WARNING : EQUATION NO. 58
WARNING : NODE NO. 10 DY DOF HAS A SINGULAR DIAGONAL = 0.000
WARNING : EQUATION NO. 56
WARNING : NODE NO. 10 RX DOF MAY BE SINGULAR.
WARNING : NODE NO. 10 RZ DOF MAY BE SINGULAR.
WARNING : NODE NO. 10 DX DOF MAY BE SINGULAR.
ELEM. : 784 OF 784
DISPLACEMENT ERROR NORM .. : 0.26854E-01 CONVERGENCE TOLERANCE .. : 0.10000E-02
ELEM. : 784 OF 784
DISPLACEMENT ERROR NORM .. : 0.12585E-01 CONVERGENCE TOLERANCE .. : 0.10000E-02
ELEM. : 784 OF 784
ENTRY STATIC ANALYSIS FOR NONLINEAR. ITERATION NO. : 4
DISPLACEMENT ERROR NORM .. : 0.15444E-22 CONVERGENCE TOLERANCE .. : 0.10000E-02
ELEM. : 784 OF 784
CONSTRUCTION STEP NO. : 4 / 14 STAGE NO : 2 STEP NO : 2
ENTRY NUMBERING_EQN
ENTRY LOAD_BLOCK
ELEM. : 784 OF 784
DISPLACEMENT ERROR NORM .. : 0.10000E+01 CONVERGENCE TOLERANCE .. : 0.10000E-02
ELEM. : 784 OF 784
DISPLACEMENT ERROR NORM .. : 0.65851E+48 CONVERGENCE TOLERANCE .. : 0.10000E-02
ELEM. : 784 OF 784
DISPLACEMENT ERROR NORM .. : Infinity CONVERGENCE TOLERANCE .. : 0.10000E-02
ELEM. : 784 OF 784
ENTRY STATIC ANALYSIS FOR NONLINEAR. ITERATION NO. : 5
DISPLACEMENT ERROR NORM .. : NaN CONVERGENCE TOLERANCE .. : 0.10000E-02
ELEM. : 784 OF 784
ENTRY STATIC ANALYSIS FOR NONLINEAR. ITERATION NO. : 6
ELEM. : 784 OF 784
ENTRY STATIC ANALYSIS FOR NONLINEAR. ITERATION NO. : 7
好像是结果验证错误,怎么修改啊?请高手帮忙
免费打赏
lwdavid1975
2010年06月06日 12:32:56
12楼
今天还有事,看了模型主要是施工阶段边界条件有问题,发个实例给你参考。
yang2596
2010年06月06日 13:09:59
13楼
谢谢!我的原题要求是用偏心转体法施工,我不会模拟,只能整成满堂支架法了!老师,你会模拟偏心转体法施工么?还有29节点应该怎么设置边界条件啊?
lwdavid1975
2010年06月06日 13:45:58
14楼
偏心转体法施工总体上可分5 个阶段:
阶段1: 浇筑所有桥墩墩的下部结构和中墩的临时固定措施; 分段浇筑上部箱梁并张拉钢束, 使箱梁和中墩形成2 个T 形刚构。
阶段2: 将浇筑好的两个T 形刚构落架, (采用转体施工将2 个T 形刚构转到线位,计算分析可不考虑)。
阶段3: 西侧T 形刚构的主梁支撑到西边墩的支座上; 施工东边墩上的箱梁现浇段, 并与东侧T 形刚构实现边跨合龙。
阶段4: 施工中跨合龙段, 张拉合龙钢束, 全桥合龙。
阶段5: 施工桥面铺装, 全桥贯通。
yang2596
2010年06月06日 15:52:49
15楼
老师,你什么时候有时间帮我修改一下吧!我自己搞不定啊!谢谢了!
ilxm0115
2010年06月07日 16:56:10
16楼
改改边界就可以了
yuyangeric
2010年06月28日 02:58:57
17楼
好东西啊啊啊啊
coolbady2010
2010年06月30日 15:05:40
18楼
应该是边界条件有误
baishengwei141
2010年07月16日 14:14:18
19楼
学习学习,正好碰见类似问题
mige0939
2011年03月06日 21:14:51
20楼
也遇到类似得错误了,真需要帮助呢,
wyh5586166
2011年03月07日 05:27:22
21楼
看不懂啊!!!
