土木毕业设计外文翻译中英对照版~~吐血共享!!!
coolman_99
coolman_99 Lv.2
2008年03月24日 11:49:35
来自于学生专栏
Tall Building StructureAbstract: This article mainly analyzes the Tall Building Structures. Including Shear-Wall Systems, Rigid-Frame Systems, Tubular Systems. Through the analysis of the most common structure styles for the high-rise architecture. We conclude that during the design progress, the reasonable style should be adopted economically .
Key words: high-rise system load
⒈Introduction
Tall towers and buildings have fascinated mankind from the beginning of civilization ,their construction being initially for defense and sequently for ecclesiastical purposes. The growth in modern tall building construction,however,which began in the 1880s,has been largely for commercial and residential purposes,but it is difficult to define a Tall Building Structure. One may say that a low-rise building ranges from 1 to 2 or 3 stories. A medium-rise building probably ranges between 3 or 4 stories up to 10 or 20 stories. Thus a high–rise building is probably one that has at least some 10 stories or more.
Although the basic principal of vertical and horizontal subsystem design remain the same for low-, medium-or Tall Building Structure, when a building gets high the vertical subsystems become a controlling problem for two reasons. Higher vertical loads will require larger columns , walls, deflections produced by lateral forces are much larger and must be carefully provided for.
The vertical subsystems in a high–rise building transmit accumulated gravity load from story to story , thus requiring larger column or wall sections to support such loading. In addition, these same vertical subsystems must transmit lateral loads , such as wind or seismic loads ,to the foundations. However , in contrast to vertical load, lateral load effects on buildings are not linear and increase rapidly with increase in height. For example, inder wind load, the overturning moment at the base of building varies approximately as the square of the height of the building, and the lateral deflections at the top of a building may vary as the fourth power of building height, other things being equal. Earthquake produces an even more pronounced effect.
When the structure for a low –or medium –rise building is designed for dead and live load , it is almost an inherent property that the columns, walls, and stair or elevator shafts can carry most of the horizontal forces. The problem is primarily one of shear resistance. Moderate addition bracing for rigid frames in “short” buildings can easily be provided by filling certain panels (or even all panels)without increasing the sizes of the columns and girders otherwise required for vertical loads.
Unfortunately, this is not so for Tall Building Structures because the problem is primarily resistance to moment and deflection rather than shear alone. Special structural arrangements will often have to be made and additional structural material is always required for the columns, girders, walls, an slabs in order to make a Tall Building Structure sufficiently resistant to much higher lateral loads an deformations.
免费打赏
hongfeng808
2010年05月11日 14:41:31
122楼
我急要,内给我一些吗,关于桥梁的, 873699773@qq.com
olyain
2010年05月15日 09:39:41
123楼
我也要一份,谢谢。 29765515@qq.com
ghoul___
2010年05月16日 18:50:35
124楼
我也要一份,谢谢。 329367212@qq.com
wang604690911
2010年05月18日 16:15:32
125楼
还有吗???大哥 给我一份 604690911@qq.com
pourquoiforwhy
2010年05月20日 21:09:27
126楼
你为什么不发上来呢
zhaohui1987@gmail.com
wegt_150
2010年05月23日 15:09:45
127楼
大哥,还有吗,能不能给我份 452743527@qq.com
niqiu1126
2010年05月25日 21:32:40
128楼
万分感谢,楼主,能否给我发一份
lijiwei1126@163.com
wisefish2008
2010年05月26日 15:57:09
129楼
赞美楼主啊
我也要一篇啊 邮箱 wisefish2008@sina.com
要带出处的
planelee
2010年05月30日 00:01:56
130楼
我是土木路桥的毕业生 现在急缺外文翻译 可以发一份我吗?
planelee
2010年05月30日 00:03:03
131楼
我是土木路桥的毕业生 现在急缺外文翻译 可以发一份我吗? www.planelee@163.com
