土木毕业设计外文翻译中英对照版~~吐血共享!!!
coolman_99
coolman_99 Lv.2
2008年03月24日 11:49:35
来自于学生专栏
Tall Building StructureAbstract: This article mainly analyzes the Tall Building Structures. Including Shear-Wall Systems, Rigid-Frame Systems, Tubular Systems. Through the analysis of the most common structure styles for the high-rise architecture. We conclude that during the design progress, the reasonable style should be adopted economically .
Key words: high-rise system load
⒈Introduction
Tall towers and buildings have fascinated mankind from the beginning of civilization ,their construction being initially for defense and sequently for ecclesiastical purposes. The growth in modern tall building construction,however,which began in the 1880s,has been largely for commercial and residential purposes,but it is difficult to define a Tall Building Structure. One may say that a low-rise building ranges from 1 to 2 or 3 stories. A medium-rise building probably ranges between 3 or 4 stories up to 10 or 20 stories. Thus a high–rise building is probably one that has at least some 10 stories or more.
Although the basic principal of vertical and horizontal subsystem design remain the same for low-, medium-or Tall Building Structure, when a building gets high the vertical subsystems become a controlling problem for two reasons. Higher vertical loads will require larger columns , walls, deflections produced by lateral forces are much larger and must be carefully provided for.
The vertical subsystems in a high–rise building transmit accumulated gravity load from story to story , thus requiring larger column or wall sections to support such loading. In addition, these same vertical subsystems must transmit lateral loads , such as wind or seismic loads ,to the foundations. However , in contrast to vertical load, lateral load effects on buildings are not linear and increase rapidly with increase in height. For example, inder wind load, the overturning moment at the base of building varies approximately as the square of the height of the building, and the lateral deflections at the top of a building may vary as the fourth power of building height, other things being equal. Earthquake produces an even more pronounced effect.
When the structure for a low –or medium –rise building is designed for dead and live load , it is almost an inherent property that the columns, walls, and stair or elevator shafts can carry most of the horizontal forces. The problem is primarily one of shear resistance. Moderate addition bracing for rigid frames in “short” buildings can easily be provided by filling certain panels (or even all panels)without increasing the sizes of the columns and girders otherwise required for vertical loads.
Unfortunately, this is not so for Tall Building Structures because the problem is primarily resistance to moment and deflection rather than shear alone. Special structural arrangements will often have to be made and additional structural material is always required for the columns, girders, walls, an slabs in order to make a Tall Building Structure sufficiently resistant to much higher lateral loads an deformations.
免费打赏
snoopy0021
2010年04月18日 11:57:16
112楼
:lol
jasonzhou_55
2010年04月18日 21:21:19
113楼
to much higher lateral loads an deformations. ????
踏步向前
2010年04月19日 12:22:40
114楼
楼主,我也想要啊
邮箱 380602505@qq.com
感激不尽啊
canghaieryue
2010年04月19日 15:00:32
115楼
大哥 你的土木论文 还有吗??
俺也想要份 xing2shen@sina.com
canghaieryue
2010年04月19日 15:02:18
116楼
大哥 你的土木论文 还有吗??
俺也想要份 上面的邮箱弄错了 应为 xing2shen4@sina.com
a5890043
2010年04月20日 21:49:30
117楼
俺也想要一份,谢谢先。 lifejust@126.com
h80608115
2010年04月21日 13:59:04
118楼
也给我吧 1071472547@qq.com
wojiubushiwo
2010年04月23日 17:30:21
119楼
也给我一份吧 562636805@qq.com
tmwsd
2010年04月28日 17:46:37
120楼
251803991@qq.com给我发一份谢谢
kjjay1314
2010年05月07日 10:19:56
121楼
大侠 可找着你了~~ 内流满面啊 kjjay1314@163.com :kiss:
