土木毕业设计外文翻译中英对照版~~吐血共享!!!
coolman_99
coolman_99 Lv.2
2008年03月24日 11:49:35
来自于学生专栏
Tall Building StructureAbstract: This article mainly analyzes the Tall Building Structures. Including Shear-Wall Systems, Rigid-Frame Systems, Tubular Systems. Through the analysis of the most common structure styles for the high-rise architecture. We conclude that during the design progress, the reasonable style should be adopted economically .
Key words: high-rise system load
⒈Introduction
Tall towers and buildings have fascinated mankind from the beginning of civilization ,their construction being initially for defense and sequently for ecclesiastical purposes. The growth in modern tall building construction,however,which began in the 1880s,has been largely for commercial and residential purposes,but it is difficult to define a Tall Building Structure. One may say that a low-rise building ranges from 1 to 2 or 3 stories. A medium-rise building probably ranges between 3 or 4 stories up to 10 or 20 stories. Thus a high–rise building is probably one that has at least some 10 stories or more.
Although the basic principal of vertical and horizontal subsystem design remain the same for low-, medium-or Tall Building Structure, when a building gets high the vertical subsystems become a controlling problem for two reasons. Higher vertical loads will require larger columns , walls, deflections produced by lateral forces are much larger and must be carefully provided for.
The vertical subsystems in a high–rise building transmit accumulated gravity load from story to story , thus requiring larger column or wall sections to support such loading. In addition, these same vertical subsystems must transmit lateral loads , such as wind or seismic loads ,to the foundations. However , in contrast to vertical load, lateral load effects on buildings are not linear and increase rapidly with increase in height. For example, inder wind load, the overturning moment at the base of building varies approximately as the square of the height of the building, and the lateral deflections at the top of a building may vary as the fourth power of building height, other things being equal. Earthquake produces an even more pronounced effect.
When the structure for a low –or medium –rise building is designed for dead and live load , it is almost an inherent property that the columns, walls, and stair or elevator shafts can carry most of the horizontal forces. The problem is primarily one of shear resistance. Moderate addition bracing for rigid frames in “short” buildings can easily be provided by filling certain panels (or even all panels)without increasing the sizes of the columns and girders otherwise required for vertical loads.
Unfortunately, this is not so for Tall Building Structures because the problem is primarily resistance to moment and deflection rather than shear alone. Special structural arrangements will often have to be made and additional structural material is always required for the columns, girders, walls, an slabs in order to make a Tall Building Structure sufficiently resistant to much higher lateral loads an deformations.
免费打赏
ppsunyip
2010年03月22日 20:55:41
102楼
楼主能发个3000字的土木方面的外文翻译吗 谢谢 sypduying@163.com
darkmatter871002
2010年03月25日 19:53:41
103楼
土木的,要文献出处和作者,先谢了,急求, 553881325@qq.com
zachary7777
2010年03月26日 13:25:33
104楼
老大,能给我一份吗?
邮箱 zachary7777@163.com
lovely0312
2010年04月06日 10:26:59
105楼
现在还能给吗?
lovely0312
2010年04月06日 10:27:45
106楼
能给的话给我一份哈,现在正在找,很感谢喽
wangyulovely@126.com
laosan1438
2010年04月06日 10:49:15
107楼
楼主要是还能看到的话 也给我一份吧
laosan1438@163.com
likunpeng1987
2010年04月06日 14:48:32
108楼
楼主有空吗,可以给我一份2000字左右的吗
wuzebing0217
2010年04月10日 02:34:22
109楼
楼主,有没有关于隧道的中英文对照论文5000字左右,急需,谢谢!邮箱是: wuzebing0217@163.com
xum0520
2010年04月11日 15:43:58
110楼
楼主帮忙翻译下Hudson ——Harrison-··-Engineering-rock-Mechanics Chapter6:Intact Rock 6.4 Specimen geometry, loading conditions
and environmental effects (P95——P105) 不胜感激 xum0520@126.com
xum0520
2010年04月11日 15:46:16
111楼
6.4Specimen geometry, loading conditions
and environmental effects 就是这一节 再次感谢
