土木毕业设计外文翻译中英对照版~~吐血共享!!!
coolman_99
coolman_99 Lv.2
2008年03月24日 11:49:35
来自于学生专栏
Tall Building StructureAbstract: This article mainly analyzes the Tall Building Structures. Including Shear-Wall Systems, Rigid-Frame Systems, Tubular Systems. Through the analysis of the most common structure styles for the high-rise architecture. We conclude that during the design progress, the reasonable style should be adopted economically .
Key words: high-rise system load
⒈Introduction
Tall towers and buildings have fascinated mankind from the beginning of civilization ,their construction being initially for defense and sequently for ecclesiastical purposes. The growth in modern tall building construction,however,which began in the 1880s,has been largely for commercial and residential purposes,but it is difficult to define a Tall Building Structure. One may say that a low-rise building ranges from 1 to 2 or 3 stories. A medium-rise building probably ranges between 3 or 4 stories up to 10 or 20 stories. Thus a high–rise building is probably one that has at least some 10 stories or more.
Although the basic principal of vertical and horizontal subsystem design remain the same for low-, medium-or Tall Building Structure, when a building gets high the vertical subsystems become a controlling problem for two reasons. Higher vertical loads will require larger columns , walls, deflections produced by lateral forces are much larger and must be carefully provided for.
The vertical subsystems in a high–rise building transmit accumulated gravity load from story to story , thus requiring larger column or wall sections to support such loading. In addition, these same vertical subsystems must transmit lateral loads , such as wind or seismic loads ,to the foundations. However , in contrast to vertical load, lateral load effects on buildings are not linear and increase rapidly with increase in height. For example, inder wind load, the overturning moment at the base of building varies approximately as the square of the height of the building, and the lateral deflections at the top of a building may vary as the fourth power of building height, other things being equal. Earthquake produces an even more pronounced effect.
When the structure for a low –or medium –rise building is designed for dead and live load , it is almost an inherent property that the columns, walls, and stair or elevator shafts can carry most of the horizontal forces. The problem is primarily one of shear resistance. Moderate addition bracing for rigid frames in “short” buildings can easily be provided by filling certain panels (or even all panels)without increasing the sizes of the columns and girders otherwise required for vertical loads.
Unfortunately, this is not so for Tall Building Structures because the problem is primarily resistance to moment and deflection rather than shear alone. Special structural arrangements will often have to be made and additional structural material is always required for the columns, girders, walls, an slabs in order to make a Tall Building Structure sufficiently resistant to much higher lateral loads an deformations.
免费打赏
wdm_2009
2010年03月02日 22:42:46
92楼
土木专业翻译文章,欢迎大家下载!
llyyll2010
2010年03月04日 16:51:15
93楼
可以发给我吗,我很急需,谢谢,498924031@QQCOM
feng-0213
2010年03月04日 18:17:57
94楼
我也急着要,最好带文献综述,谢谢
cyc19881222
2010年03月05日 15:31:41
95楼
bxhwan
2010年03月06日 14:19:32
96楼
bxhwan999@qq.com
謝謝樓主分享~~~~~~~~
lz0611250134
2010年03月06日 14:55:37
97楼
非常感谢 有2009年6月份后的 外文期刊 原文PDF 和 翻译吗?? 有的话 麻烦发我 lzxiaolei@126.com 或者 QQ 672705297 不胜感谢
pcy1987
2010年03月08日 17:29:19
98楼
土木工程外文翻译还有没,发我分,急用, 295729040@qq.com,要有中文和英文的,谢谢
stein8639
2010年03月09日 19:47:55
99楼
LZ 怎么搞的 没有放:L
yuky2002
2010年03月17日 19:10:29
100楼
大哥,你这话放出来有点吓人啊,不过我还是恬不知耻地想跟你要一份,最好是钢结构的,2008年以后的,这是我的邮箱: allenyuky@yahoo.cn
有的话麻烦给我发一份吧,在此先谢过了。
songguoj
2010年03月17日 20:50:47
101楼
可以可以也给我一份啊,谢谢楼主大人了,我的邮箱是 songguoj88@163.com,先谢谢喽~~~
