土木毕业设计外文翻译中英对照版~~吐血共享!!!
coolman_99
coolman_99 Lv.2
2008年03月24日 11:49:35
来自于学生专栏
Tall Building StructureAbstract: This article mainly analyzes the Tall Building Structures. Including Shear-Wall Systems, Rigid-Frame Systems, Tubular Systems. Through the analysis of the most common structure styles for the high-rise architecture. We conclude that during the design progress, the reasonable style should be adopted economically .
Key words: high-rise system load
⒈Introduction
Tall towers and buildings have fascinated mankind from the beginning of civilization ,their construction being initially for defense and sequently for ecclesiastical purposes. The growth in modern tall building construction,however,which began in the 1880s,has been largely for commercial and residential purposes,but it is difficult to define a Tall Building Structure. One may say that a low-rise building ranges from 1 to 2 or 3 stories. A medium-rise building probably ranges between 3 or 4 stories up to 10 or 20 stories. Thus a high–rise building is probably one that has at least some 10 stories or more.
Although the basic principal of vertical and horizontal subsystem design remain the same for low-, medium-or Tall Building Structure, when a building gets high the vertical subsystems become a controlling problem for two reasons. Higher vertical loads will require larger columns , walls, deflections produced by lateral forces are much larger and must be carefully provided for.
The vertical subsystems in a high–rise building transmit accumulated gravity load from story to story , thus requiring larger column or wall sections to support such loading. In addition, these same vertical subsystems must transmit lateral loads , such as wind or seismic loads ,to the foundations. However , in contrast to vertical load, lateral load effects on buildings are not linear and increase rapidly with increase in height. For example, inder wind load, the overturning moment at the base of building varies approximately as the square of the height of the building, and the lateral deflections at the top of a building may vary as the fourth power of building height, other things being equal. Earthquake produces an even more pronounced effect.
When the structure for a low –or medium –rise building is designed for dead and live load , it is almost an inherent property that the columns, walls, and stair or elevator shafts can carry most of the horizontal forces. The problem is primarily one of shear resistance. Moderate addition bracing for rigid frames in “short” buildings can easily be provided by filling certain panels (or even all panels)without increasing the sizes of the columns and girders otherwise required for vertical loads.
Unfortunately, this is not so for Tall Building Structures because the problem is primarily resistance to moment and deflection rather than shear alone. Special structural arrangements will often have to be made and additional structural material is always required for the columns, girders, walls, an slabs in order to make a Tall Building Structure sufficiently resistant to much higher lateral loads an deformations.
免费打赏
eminem3
2010年06月01日 23:43:51
132楼
能不能给我一份?看上去不错!wtd@163。com
yhjun2012
2010年06月02日 12:55:31
133楼
老大请给我一份 397659699@qq.com 工民建的 字数在5000以上 谢谢了
kadic
2010年06月04日 11:13:41
134楼
顶啊顶
damiao005509
2010年06月04日 12:16:47
135楼
可以发给我吗?我的邮箱 409146213@qq.com
bgyhhk123
2010年06月09日 12:11:03
136楼
谢谢楼组可不可以给我发一份啊 american200@sina.com,非常感谢啊
gt370490091
2010年06月09日 18:42:11
137楼
这是骗回帖的么???
mingyan20062010
2010年06月10日 14:15:39
138楼
土木的道路方面的英文翻译3000字以上
非常感谢
xiangbiye2010@163.com
liuyuebin1987
2010年06月14日 12:09:29
139楼
xiexie
advyu415
2010年06月21日 21:47:33
140楼
楼主在么,我后天就要检查了,麻烦发下邮箱 advyu@126.com,谢谢~~~
advyu415
2010年06月21日 21:48:47
141楼
字数是5000字以上的~~~万分感谢啊~~~
