本帖最后由 jewelo06 于 2013-11-7 11:47 编辑 把2013年注册考试定义为天灾人祸。OVER
12楼
这么低的通过率,绝对是老朱玩大了!
不过老朱不会承认的,他会说是上面要求卡人的!
13楼
对比往年真题,今年确实很难,城市桥梁连规范都没有,一下丢掉4分,原来新的城A级就等于公路一级,感觉很冤。去年题太烂,今年出难题找回面子。既不是选择题,又不是计算题,很不合理。
http://ncees.org/exams/pe-exam/
Scoring process Licensing exams differ from most other exams. After each administration, every NCEES exam undergoes extensive statistical analysis to determine the minimum level of performance required for entry into the profession. This rigorous process helps ensure an equitable licensure system for candidates while upholding the standards of the profession. The steps are as follows:
- NCEES scans all answer sheets as they are received from the states. Answer sheets are flagged for review when they are missing critical information, such as the depth module that the examinees selected or candidate ID numbers. The scoring process continues only when these issues are resolved.
- A psychometric analysis is performed on a sample of answer sheets from each multiple-choice exam to identify any questions with unusual statistics. These questions are flagged for review.
- At least two subject-matter experts, who are licensed engineers or surveyors, review the flagged items. In addition, NCEES reviews all examinee comment forms, and the subject-matter experts consider comments on the forms about specific exam questions. If the reviews confirm an error in a question, credit may be given for more than one answer.
- When the analyses and reviews are completed, NCEES changes the answer keys as necessary. The passing score and final correct answers for each exam are then used to score all the answer sheets. Scanners are calibrated before and during scoring. A percentage of the answer sheets are manually verified, and the results are compared to the machine score to ensure accuracy.
- NCEES releases the results to the licensing boards and testing agencies, who in turn report the results to examinees.
上面第三条说两位主审如果发现题目有错误,会给出多于一个的答案。
14楼
今年机读通过率是多少啊?哪里通知了机读通过率啊
15楼
支持下。个人感觉今年通过率会很低,确实题目难。老朱一年一改革,口口声声是好题,怀着一副推进改革,天下结构为己任的心怀。但考生们毕竟多数经不起这样的变化。慢点慢点来,尤其是提前说声。好不累?
16楼
今年的通过率到底是多少啊????????
17楼
撸主不要危言耸听,请拿出具体可靠的数据来,如果仅凭个人臆测,发言还是谨慎为妙!
18楼
楼主是在哪里得到机读通过率的啊?
19楼
楼主哝哝哝说了半天也没说出一个机读通过率的数字出来,你到底要说什么?
20楼
我也是辞职考的,从楼主字里行间 “淡定”看出不难,我觉得非常难,首先风格的改变应该只有一种方法比较容易过考试。往年送分题大大减少了。而偏门冷僻题多了非常。做过真题的都知道一般搞生题正确率高不了太多了。所以只有以超高的正确率把会做,见过脸熟的保证了再攻克生题。这时候做题数量肯定多不了哪去。也就六十来道题的。要多大的自信才有可能呢啊。而纵观往年,虽然大伙都说做不难,但对于练习足够的人来说做题70+还是可以期盼吧。不要老说正确是王道,但是70+的一般都可以回家呼呼大睡了。
21楼
总的说来是不是老朱步子迈的太大,就是小伙伴们掉队了。机读通过率这个一般等今年评完卷子划好分数线可能会有知情人士透露一二,别的时候,大都是讳莫如深的,一点也不透明,透明了就会损害一些人的应得利益,就好像三公经费公开一样,哎。还是叹息一声了得:lol
