条形捆扎交货形式 圆盘交货形式 施工机具 A1:场地布置合理,原材料与半成品分开堆放 A2:材料标识牌,600*450mm A3:长条钢筋采用塔吊直接吊运,严禁单股钢丝绳吊运(打‘×’表示错误做法) A4:箍筋采用料斗吊运,严禁装载超过料具上口(打‘×’表示错误做法) A5
![215235ppz3oz6pwpinwae9.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
条形捆扎交货形式
![215235rr3cenayawibfxcf.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
圆盘交货形式
![215235ww3jjyitwy0y5iay.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
施工机具
![21523657k7jlcv7l5j0n7j.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
![215236kkoiu0oao31ri612.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A2:材料标识牌,600*450mm
![21523607quybc4rlllv01g.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
![2152368nbb8kdzop3qejku.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
![215236v4q0c0g8pqlv4s58.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
![215236dd9zs96z6jn3e9tm.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
![215236krrk61fkffgm718g.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
![21523783o2ovnxjl8y5jai.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A5:墙柱钢筋绑扎要求画线绑扎,水平(箍筋)钢筋间距满足设计要求,水平筋或箍筋与每根主筋相交位置绑扎到位,严禁跳绑
![2152373zkqvbjyzj9ow6dd.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A6:钢筋在浇筑混凝土前,用PVC管保护主筋不受污染
![2152376st6tvsrls0v664e.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A7:距离浇筑板面500mm处加箍筋,固定柱主筋偏位
![2152372nxbrt8cvcvbvt7r.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A8:墙、柱钢筋直径≥20mm,采用机械接头
![215237ra0azkgfkjfamogf.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A9:墙、柱钢筋直径<20mm,采用电渣压力焊
A10:柱核心区箍筋:加工焊接成如图所示钢筋笼,梁钢筋绑扎完成时一同下沉到预定位置
![21584220ri4sb2fsc51qzi.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A11:梁钢筋绑扎主筋间距分布均匀,箍筋绑扎到位(箍筋与每根主筋相交位置必须有效绑扎牢固)
![2158421c6nf8tg11oft66w.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A12:梁主筋直径≥20mm,采用机械接头;梁主筋<20mm采用焊接或绑扎搭接
![215843wcyymqyqfadwtqfw.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A13:主次梁交接处,主梁方向箍筋在交接位置按设计图纸间距绑扎
![2158430trez7ib0s7btsbe.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A14:梁、柱箍筋按抗震要求,弯成135度角
![2158435yc3tb5b1r555t5b.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A14:梁钢筋一排筋与二排筋采用分隔筋隔开,分隔筋直径≥主筋直径或25mm;分隔筋距支座边500mm设置一道,中间每隔3m设置一道
![215843udu7st7ia788as7s.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A15:板面筋在边支座锚固时,直接延伸到梁最外面一根钢筋的内侧弯下
![215843cmfnzrxntbmpptnb.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A16:板配筋采用双层双向+分离式配筋,取消分离式配筋形式(面筋推荐不小于Ф8,具体以设计为准)
![215843mni6xgxi464piznn.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A17: 面筋锚固端与梁箍筋(主筋)、墙主筋(水平筋)绑扎牢固,面筋绑扎要满绑
![215844fpv7a1madbf57z7z.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A18:板底筋绑扎前,画线控制间距,建议采用弹线控制
![215844a5a5b55bf9ssesuf.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A19:板面筋采用满绑(纵横钢筋交接位置都必须进行绑扎),不得出现‘隔一绑一’的跳绑形式
![215844ni7r7vnrhpih677r.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A20: 楼板上预留洞口≥500mm,封口处采用U型钢筋
![2158447774bg7nz6n7bs7v.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A21: 板内阳角增加7根直径同板面筋的放射钢筋,长度不小于1700mm
![215844wa35w3aw1y95ffmy.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A22:柱、墙钢筋垫块:墙、柱采用成品塑胶内撑条,纵横间距≤600mm;柱主筋垫块采用成品塑胶垫块,沿柱角部≤600mm设置一个,墙体纵横间距≤600mm
![2158440god6g4j4466vcjj.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A23:板(梁)底筋垫块:采用预制成品垫块,板间距1000*1000mm;梁底部每500mm布置2个放置在角筋位置
A24:板面筋垫块:采用H型预制成品垫块。间距600*600mm
![2202206e5ntjfmmtnze5t5.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A25:钢筋搭接焊:表面平整、光滑,无凹陷、焊瘤、裂纹、气孔、咬边、夹渣等质量缺陷,雨天严禁作业
![220220kqqzxrzd2ppmnrqn.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A26:电渣压力焊:焊包凸出面不少于4mm,不得出现偏心、气孔、裂缝、咬边、夹渣等缺陷,雨天严禁作业
![220220x2nl25zx0qwjdlxn.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A27:墙上埋管采用钢筋焊接固定
![2202205c02ppzzkpza54hx.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A28:断开的箍筋与止水钢板焊接
![220220v1nblocytesebyod.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A29:钢筋混凝土墙体上预留洞采用钢模预埋定位
![2202204fxfwiz4zififi4a.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A30:钢筋混凝土中采用预PVC止水节
![2202212zze2v925zz4mzvg.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A31:厨卫间反砍采用配筋混凝土,Φ6@400的U型箍筋,与钢筋同时绑扎安装
![220221vvgc4nxgrfrccc3y.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A32:预埋线盒采用钢筋加固,交叉位置与墙体钢筋焊接牢固
![220221o2uhgpohzummg3zo.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A33:落水管、地漏等穿楼板的管道采用成品PVC止水节,利用模板上双控线精确定位
![220221vz8a0vmvk9vv8rc2.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A34:钢筋加工成型挂标识(使用部位、规格、数量等)
![220221ag9kkg592mchbjd1.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A35:现场设置工序验收牌
![220222yfrvlzpyxf0p9p4f.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A36:梁绑扎完成后,采用吸尘器将梁底清理干净后沉梁
![2202220y72tl00ticsst9b.jpg](http://g.co188.com/img/topics/new_topics/images/blank.gif)
A37:板筋绑扎完成后效果(板面垃圾清理干净)
