专业英语
wit16
wit16 Lv.3
2005年07月28日 15:30:29
六. 基坑开挖与降水 1 excavation开挖(挖方) 2 dewatering(基坑)降水 3 failure of foundation基坑失稳 4 bracing of foundation pit基坑围护 5 bottom heave=basal heave (基坑)底隆起 6 retaining wall挡土墙 7 pore-pressure distribution孔压分布
六. 基坑开挖与降水
1 excavation开挖(挖方)
2 dewatering(基坑)降水
6 retaining wall挡土墙
8 dewatering method降低地下水位法
9 well point system井点系统(轻型)
10 deep well point深井点
11 vacuum well point真空井点
12 braced cuts支撑围护
13 braced excavation支撑开挖
14 braced sheeting支撑挡板
七. 深基础--deep foundation
1.pile foundation桩基础
1)cast –in-place灌注桩
diving casting cast-in-place pile沉管灌注桩
bored pile钻孔桩
special-shaped cast-in-place pile机控异型灌注桩
piles set into rock嵌岩灌注桩
rammed bulb pile夯扩桩
2)belled pier foundation钻孔墩基础
drilled-pier foundation钻孔扩底墩
under-reamed bored pier
3)precast concrete pile预制混凝土桩
4)steel pile钢桩
steel pipe pile钢管桩
steel sheet pile钢板桩
5)prestressed concrete pile预应力混凝土桩
prestressed concrete pipe pile预应力混凝土管桩
2.caisson foundation沉井(箱)
3.diaphragm wall地下连续墙 截水墙
4.friction pile摩擦桩
5.end-bearing pile端承桩
6.shaft竖井;桩身
7.wave equation analysis波动方程分析
8.pile caps承台(桩帽)
9.bearing capacity of single pile单桩承载力
10.lateral pile load test单桩横向载荷试验
11.ultimate lateral resistance of single pile单桩横向极限承载力
12.static load test of pile单桩竖向静荷载试验
13.vertical allowable load capacity单桩竖向容许承载力
14.low pile cap低桩承台
15.high-rise pile cap高桩承台
16.vertical ultimate uplift resistance of single pile单桩抗拔极限承载力
17.silent piling静力压桩
18.uplift pile抗拔桩
19.anti-slide pile抗滑桩
20.pile groups群桩
21.efficiency factor of pile groups群桩效率系数(η)
22.efficiency of pile groups群桩效应
23.dynamic pile testing桩基动测技术
24.final set最后贯入度
25.dynamic load test of pile桩动荷载试验
26.pile integrity test桩的完整性试验
27.pile head=butt桩头
28.pile tip=pile point=pile toe桩端(头)
29.pile spacing桩距
30.pile plan桩位布置图
31.arrangement of piles =pile layout桩的布置
32.group action群桩作用
33.end bearing=tip resistance桩端阻
34.skin(side) friction=shaft resistance桩侧阻
35.pile cushion桩垫
36.pile driving(by vibration) (振动)打桩
37.pile pulling test拔桩试验
38.pile shoe桩靴
39.pile noise打桩噪音
40.pile rig打桩机
八. 地基处理--ground treatment
1.technical code for ground treatment of building建筑地基处理技术规范
2.cushion垫层法
3.preloading预压法
4.dynamic compaction强夯法
5.dynamic compaction replacement强夯置换法
6.vibroflotation method振冲法
7.sand-gravel pile砂石桩
8.gravel pile(stone column)碎石桩
9.cement-flyash-gravel pile(CFG)水泥粉煤灰碎石桩
10.cement mixing method水泥土搅拌桩
11.cement column水泥桩
12.lime pile (lime column)石灰桩
13.jet grouting高压喷射注浆法
14.rammed-cement-soil pile夯实水泥土桩法
15.lime-soil compaction pile 灰土挤密桩
lime-soil compacted column灰土挤密桩
lime soil pile灰土挤密桩
16.chemical stabilization化学加固法
17.surface compaction表层压实法
18.surcharge preloading超载预压法
19.vacuum preloading真空预压法
20.sand wick袋装砂井
21.geofabric ,geotextile土工织物
22.composite foundation复合地基
23.reinforcement method加筋法
24.dewatering method降低地下水固结法
25.freezing and heating冷热处理法
26.expansive ground treatment膨胀土地基处理
27.ground treatment in mountain area山区地基处理
28.collapsible loess treatment湿陷性黄土地基处理
29.artificial foundation人工地基
30.natural foundation天然地基
31.pillow褥垫
32.soft clay ground软土地基
33.sand drain砂井
34.root pile树根桩
35.plastic drain塑料排水带
36.replacement ratio(复合地基)置换率
34839f88d6935c51655e.rar
10.6 KB
立即下载
免费打赏
jts3
2006年09月10日 18:05:16
12楼
有资料就收藏 有备无患
wit16
2006年09月14日 11:27:17
13楼
四. 渗透性和渗流
1.Darcy’s law 达西定律
2.piping管涌
3.flowing soil流土
4.sand boiling砂沸
5.flow net流网
6.seepage渗透(流)
7.leakage渗流
8.seepage pressure渗透压力
9.permeability渗透性
10.seepage force渗透力
11.hydraulic gradient水力梯度
12.coefficient of permeability渗透系数
五. 地基应力和变形
1.soft soil软土
2.(negative) skin friction of driven pile打入桩(负)摩阻力
3.effective stress有效应力
4.total stress总应力
5.field vane shear strength十字板抗剪强度
6.low activity低活性
7.sensitivity灵敏度
8.triaxial test三轴试验
9.foundation design基础设计
10.recompaction再压缩
11.bearing capacity承载力
12.soil mass土体
13.contact stress (pressure)接触应力(压力)
14.concentrated load集中荷载
15.a semi-infinite elastic solid半无限弹性体
16.homogeneous均质
17.isotropic各向同性
18.strip footing条基
19.square spread footing方形独立基础
20.underlying soil (stratum ,strata)下卧层(土)
21.dead load =sustained load恒载 持续荷载
22.live load活载
23.short –term transient load短期瞬时荷载
24.long-term transient load长期荷载
25.reduced load折算荷载
26.settlement沉降
27.deformation变形
28.casing套管
29.dike=dyke堤(防)
30.clay fraction粘粒粒组
31.physical properties物理性质
32.subgrade路基
33.well-graded soil级配良好土
34.poorly-graded soil级配不良土
35.normal stresses正应力
36.shear stresses剪应力
37.principal plane主平面
38.major (intermediate, minor) principal stress最大(中、最小)主应力
39.Mohr-Coulomb failure condition摩尔-库仑破坏条件
40.FEM=finite element method有限元法
41.limit equilibrium method极限平衡法
42.pore water pressure孔隙水压力
43.preconsolidation pressure先期固结压力
44.modulus of compressibility压缩模量
45.coefficent of compressibility压缩系数
46.compression index压缩指数
47.swelling index回弹指数
48.geostatic stress自重应力
49.additional stress附加应力
50.total stress总应力
51.final settlement最终沉降
52.slip line滑动线
jts3
2006年09月15日 22:35:30
14楼
楼主 冒昧地问一个问题:这么多的单词你都掌握了吗? 咳~~ 其实我单词都认识 可是如果你让我写“渗透系数”我还真写不出来 悲哀啊~~~
wit16
2006年09月20日 16:52:41
15楼
水利水电工程英汉(汉英)词典
qvqvq
2006年09月24日 17:46:51
16楼
感谢楼主的提供!我们经常做世界银行贷款项目的工程!所以每次遇到文件翻译就要了命!特别是专业英语!就是一般的翻译都没办法!再次感谢!
zzh_sh
2007年01月14日 11:50:31
17楼
下载一份,以有备无患啊,呵呵,谢谢了!
xiaolei1315
2007年02月16日 11:47:23
18楼
现在的研究生复试比重的加大以及对与学生综合能力的要求提高,使得那些不是没希望参加复试的学生门越加注意这个 专业英语方面的学习.毕竟在复试中的英语会话以及听力是其中一环,能得就得
lililaday
2007年03月02日 11:40:24
19楼
有没有好的学习方法阿,指导一下阿
xiaolei1315
2007年05月05日 09:45:41
20楼
我学专业的方法就是先对中文的熟悉些,再看点外文的,慢慢的对照着看。
我在复试中的专业是水工建筑物,看的是天津大学版的,感觉很好,因为是中文教材,后面的重点专业英语单词。闲时翻翻看,能够记住。
专业英语这种学习,就跟比画着学说话一样。
重点专业单词会了,普通的语法咱们又知道,专业英语方面就解决了
mingyue_163
2007年05月10日 13:44:10
21楼
书到用时方恨少,平时积累吧
