土木毕业设计外文翻译中英对照版~~吐血共享!!!
coolman_99
coolman_99 Lv.2
2008年03月24日 11:49:35
来自于学生专栏
Tall Building StructureAbstract: This article mainly analyzes the Tall Building Structures. Including Shear-Wall Systems, Rigid-Frame Systems, Tubular Systems. Through the analysis of the most common structure styles for the high-rise architecture. We conclude that during the design progress, the reasonable style should be adopted economically .
Key words: high-rise system load
⒈Introduction
Tall towers and buildings have fascinated mankind from the beginning of civilization ,their construction being initially for defense and sequently for ecclesiastical purposes. The growth in modern tall building construction,however,which began in the 1880s,has been largely for commercial and residential purposes,but it is difficult to define a Tall Building Structure. One may say that a low-rise building ranges from 1 to 2 or 3 stories. A medium-rise building probably ranges between 3 or 4 stories up to 10 or 20 stories. Thus a high–rise building is probably one that has at least some 10 stories or more.
Although the basic principal of vertical and horizontal subsystem design remain the same for low-, medium-or Tall Building Structure, when a building gets high the vertical subsystems become a controlling problem for two reasons. Higher vertical loads will require larger columns , walls, deflections produced by lateral forces are much larger and must be carefully provided for.
The vertical subsystems in a high–rise building transmit accumulated gravity load from story to story , thus requiring larger column or wall sections to support such loading. In addition, these same vertical subsystems must transmit lateral loads , such as wind or seismic loads ,to the foundations. However , in contrast to vertical load, lateral load effects on buildings are not linear and increase rapidly with increase in height. For example, inder wind load, the overturning moment at the base of building varies approximately as the square of the height of the building, and the lateral deflections at the top of a building may vary as the fourth power of building height, other things being equal. Earthquake produces an even more pronounced effect.
When the structure for a low –or medium –rise building is designed for dead and live load , it is almost an inherent property that the columns, walls, and stair or elevator shafts can carry most of the horizontal forces. The problem is primarily one of shear resistance. Moderate addition bracing for rigid frames in “short” buildings can easily be provided by filling certain panels (or even all panels)without increasing the sizes of the columns and girders otherwise required for vertical loads.
Unfortunately, this is not so for Tall Building Structures because the problem is primarily resistance to moment and deflection rather than shear alone. Special structural arrangements will often have to be made and additional structural material is always required for the columns, girders, walls, an slabs in order to make a Tall Building Structure sufficiently resistant to much higher lateral loads an deformations.
免费打赏
qwieni
2009年05月14日 15:52:36
72楼
太感谢了
qwieni@sina.com
lq214739185
2009年05月15日 13:08:20
73楼
liuqiang7570@yahoo.com.cn
急需!!!!
谢谢老大了
alphashen
2009年05月18日 21:21:20
74楼
alphawise@hotmail.com
最好中文8000字以上
谢谢啦。。。。
chen412857896
2009年05月19日 15:07:26
75楼
不知道现在才要晚不晚,如果楼主看到的话,就给小弟也发一个吧,英文单词在3000左右
412857896@qq。com,不胜感激
hzj123245
2009年05月23日 16:31:48
76楼
wo ye yao :Q :Q :Q
lwtkm2005
2009年05月24日 19:32:17
77楼
lwtddq@163.com 谢谢了
sastao
2009年05月25日 00:45:06
78楼
急需呀。各位老大谁有就给我发个吧
不胜感激
hytao1985@163.com
rab198
2009年05月25日 16:56:59
79楼
fhqjy
2009年05月25日 23:10:32
80楼
fhqjyjj@126.com
谢谢了,五千字左右的就行!
lovewinterly
2009年05月31日 01:12:07
81楼
关于港口方面的,要文献出处和作者,先谢了,急求,
邮箱: lovewinterly@126.com
