土木毕业设计外文翻译中英对照版~~吐血共享!!!
coolman_99
coolman_99 Lv.2
2008年03月24日 11:49:35
来自于学生专栏
Tall Building StructureAbstract: This article mainly analyzes the Tall Building Structures. Including Shear-Wall Systems, Rigid-Frame Systems, Tubular Systems. Through the analysis of the most common structure styles for the high-rise architecture. We conclude that during the design progress, the reasonable style should be adopted economically .
Key words: high-rise system load
⒈Introduction
Tall towers and buildings have fascinated mankind from the beginning of civilization ,their construction being initially for defense and sequently for ecclesiastical purposes. The growth in modern tall building construction,however,which began in the 1880s,has been largely for commercial and residential purposes,but it is difficult to define a Tall Building Structure. One may say that a low-rise building ranges from 1 to 2 or 3 stories. A medium-rise building probably ranges between 3 or 4 stories up to 10 or 20 stories. Thus a high–rise building is probably one that has at least some 10 stories or more.
Although the basic principal of vertical and horizontal subsystem design remain the same for low-, medium-or Tall Building Structure, when a building gets high the vertical subsystems become a controlling problem for two reasons. Higher vertical loads will require larger columns , walls, deflections produced by lateral forces are much larger and must be carefully provided for.
The vertical subsystems in a high–rise building transmit accumulated gravity load from story to story , thus requiring larger column or wall sections to support such loading. In addition, these same vertical subsystems must transmit lateral loads , such as wind or seismic loads ,to the foundations. However , in contrast to vertical load, lateral load effects on buildings are not linear and increase rapidly with increase in height. For example, inder wind load, the overturning moment at the base of building varies approximately as the square of the height of the building, and the lateral deflections at the top of a building may vary as the fourth power of building height, other things being equal. Earthquake produces an even more pronounced effect.
When the structure for a low –or medium –rise building is designed for dead and live load , it is almost an inherent property that the columns, walls, and stair or elevator shafts can carry most of the horizontal forces. The problem is primarily one of shear resistance. Moderate addition bracing for rigid frames in “short” buildings can easily be provided by filling certain panels (or even all panels)without increasing the sizes of the columns and girders otherwise required for vertical loads.
Unfortunately, this is not so for Tall Building Structures because the problem is primarily resistance to moment and deflection rather than shear alone. Special structural arrangements will often have to be made and additional structural material is always required for the columns, girders, walls, an slabs in order to make a Tall Building Structure sufficiently resistant to much higher lateral loads an deformations.
免费打赏
wangyue91
2009年04月05日 11:37:02
62楼
sword4863
2009年04月06日 20:26:13
63楼
希望要一份~~谢谢楼主
sword4863@126.com
isoue
2009年04月29日 13:22:35
64楼
我也饱受煎熬 多谢楼主~~
a151477615
2009年04月29日 16:54:26
65楼
我也想要啊 给我一份
huazai986@163.com
a151477615
2009年04月29日 16:55:35
66楼
土木建筑有关的都行。。
huazai986@163.com
a151477615
2009年04月29日 16:58:04
67楼
10000字符以上的土木建筑的
给我一份
谢谢楼主
huazai986@163.com
anxiang333
2009年05月04日 21:54:10
68楼
anxiang333@163.com
谢谢了大哥
yingzi606
2009年05月07日 16:43:10
69楼
楼主可否也给我发一下,土木建筑方面的,感激不尽~
邮箱: 606yingzi@163.com
akrios
2009年05月12日 13:42:51
70楼
麻烦楼主也给我发一份吧
fanyunfeigood@sohu.com
感激万分啊 最好是钢结构方面的 2000-3000字
[ 本帖最后由 akrios 于 2009-5-12 14:04 编辑 ]
akrios
2009年05月12日 14:03:39
71楼
俄··网络问题 发了两次 编辑掉:loveliness:
