架空两层 立面镂空,眼前一亮的办公楼设计
设计师之友
2020年09月10日 15:00:49
德国·阿迪达斯竞技场 Behnisch Architekten 阿迪达斯竞技场在黑措根奥拉赫(Herzogenaurach)的阿迪达斯世界体育园区形成了一个独特的地标。新的办公楼和接待大楼标志着校园的主要入口,欢迎游客来到阿迪达斯集团的体育世界总部,并赋予其强烈的视觉形象。 场馆的建筑功能和表现力兼而有之,其雕塑般的造型强调了阿迪达斯所代表的对运动的激情。52000平方米的建筑面积为近2000名员工提供了一个灵活、有机的现代可持续工作空间。
德国·阿迪达斯竞技场
The adidas ARENA forms a distinctive landmark on the adidas World of Sports campus in Herzogenaurach. The new office and reception building marks the campus’s main entrance, welcoming visitors to the adidas group’s World of Sports headquarters and lending it a strong visual identity. The ARENA’s architecture is both functional and expressive, its sculptural shape emphasizing the passion for sports that adidas represents. A floor area of 52,000 square meters provides nearly 2,000 employees with modern and sustainable workspace organized on flexible, organic principles.
竞技场建筑背后的建筑理念是建立在透明度、景观和现代工作理念之间的完美平衡的基础上的,这些理念基于跨专业领域的沟通和互动以及对未来发展的响应。其结果是一个引人注目的地标,由一个抽象的体量构成,其中包含三个工作区楼层,这些楼层悬浮在一个建模的景观之上。
这座雕塑的小山容纳了建筑的入口区域,其中一部分是公共入口,通向一个宽敞明亮的中庭,适合举办各种活动。
The architectural idea behind the ARENA building is predicated on a finely balanced interplay between transparency, landscape, and a modern concept of work based on communication and interaction across professional fields as well as responsiveness to future developments. The result is a striking landmark formed by an abstract volume housing three workspace floors that hovers above a modeled landscape. This sculpted hill accommodates the building’s entrance area, part of which is publicly accessible, leading to a vast bright atrium suitable for a variety of events.
竞技场建筑的核心是中庭戏剧性的浮动楼梯。通过明亮和宽敞的采光井,它将员工带到三层的工作区,并提供了令人兴奋的中庭视野,穿过校园的露天平台,并上升至办公室楼层。一条中央的“主要街道”将这三层垂直和水平连接起来,创造出一个类似于悬在半空中的生机勃勃的市场的空间。
The heart of the ARENA building is the dramatic floating staircase in the atrium. Rising through the bright and spacious light well, it takes employees up to the three-story workspace section and offers exciting views into the atrium, across the open-air level out over the campus, and up to the office floors. A central “main street” links these three levels both vertically and horizontally to create a space akin to a lively marketplace suspended in mid-air.
在每层楼,“主街”由六个厨房中心相连,代表六个具有独特材料、颜色和家具类型的“重点城市”,形成建筑内部的独立地址。社区形成并延伸到工作空间,鼓励根据“重点城市”概念发展不同的地方特色。
在所有三层,工作区与正式和非正式会议区和娱乐区交替使用。它们被组织成杂色的星团,围绕着不同大小的光井进行优化,以提供充足的自然光。
On each floor, the “main street” is adjoined by six kitchen hubs representing six “key cities” characterized by distinctive materials, colors, and types of furnishing to form individual addresses within the building. Neighborhoods take shape and extend into the workspace, encouraging the development of differentiated local identities in line with the “key cities” concept. On all three floors, work areas alternate with areas for formal and informal meetings and recreational zones. They are organized as variegated clusters around light wells of different sizes optimized to supply ample natural light.
立面配备了专门开发的太阳控制和遮阳系统,以适应每个立面的朝向。它优化了最大透光率(包括冬季)和最小热增益之间的相互作用。固定式外部遮阳系统主要由安装在铝框架上的不透明穿孔板组成。由于采用了最新的能效标准和广泛使用可回收材料,该建筑已提交LEED金牌认证。
The facade was equipped with a specially developed sun control and shading system adapted to the orientation of each facade. It optimizes the interplay between maximum light transmittance, including in winter, and minimum heat gain. The fixed external shading system mainly consists of opaque and perforated sheets mounted on an aluminum frame. Thanks to its implementation of up-to-date energy-efficiency standards and extensive use of recyclable materials, the building has been submitted for LEED Gold certification.
建筑设计是结构工程领域的一个重大挑战,它是通过钢筋混凝土结构和倾斜的钢筋混凝土支撑系统来实现的。由于其在结构工程方面的成就,竞技场大楼于2019年初获得德国钢结构工业协会(Bauforumstahl E.V.)颁发的工程奖。
The architectural design, which represented a significant challenge in terms of structural engineering, was realized using a steel-and-concrete construction and a system of slanted steel and concrete supports. For its achievements in structural engineering, the ARENA building was honored with the Engineering Award of the German steel construction industry association bauforumstahl e. V. early in 2019.
平面图
南立面
西立面
墙立面
剖面图
建筑师: Behnisch Architekten
地点: 德国
面积: 52000.0平方米
年份: 2019
免费打赏
张哈哈哥
2020年09月14日 17:28:18
13楼
可以可以的资料,学习了。不错
jzd蒋
2020年09月15日 09:36:13
14楼
外观是不是象鞋垫的造型。有特色
老有所为
2020年09月16日 00:02:02
15楼
场馆的建筑功能和表现力兼而有之,其雕塑般的造型强调了阿迪达斯所代表的对运动的激情,谢谢分享。
liwangy
2020年09月21日 14:23:10
17楼
阿迪达斯竞技场在黑措根奥拉赫(Herzogenaurach)的阿迪达斯世界体育园区形成了一个独特的地标。新的办公楼和接待大楼标志着校园的主要入口,欢迎游客来到阿迪达斯集团的体育世界总部,并赋予其强烈的视觉形象——感谢分享!
