下图是否是一张真实图片?绝大多数人一定会毫不犹豫地回答“是”,但是事实是这是画出来的。波兰电脑绘图高手Lukasz Szeflinski某天突发奇想以网上一张美女照片为临摹对象,用电脑创造出了这幅栩栩如生,细节极其丰富的照片级图片。
12楼
Instead of focusing on one particular detail I prefer to work on the entire image. For that reason, there is a bit of color everywhere.
13楼
At this point, let me explain my choice of “Pen Pressure Control” for “Opacity Jitter” and “Flow Jitter” in “Other Dynamics”. Basically, with those settings I can easily achieve a nice color blending. Using only “Pen Pressure Control” for “Opacity Jitter” it’s much harder to achieve nice transitions between colors. Here are some examples of the effects that I have achieved.
14楼
Using “Pen Pressure Control” for “Opacity Jitter” and “Flow Jitter” transitions are much smoother to achieve with less brush strokes:
15楼
Apart from the above, there are really no more tricks; just a lot of patience, close examining of the real photograph and painting, painting and once again painting.
Let’s come back to filling image with colors:
16楼
I still have my sketch visible on the top layer to get filled all shapes:
17楼
At this point I am going to turn off the sketch layer and start working only with color, shading and highlights:
18楼
I slowly shape the image by adding shadows and highlights:
19楼
This time, I am going to add more details in the hair area:
20楼
Then, I will pass on to the face area:
21楼
Now I am going to work a bit on the background (right curtain):
