土木毕业设计外文翻译中英对照版~~吐血共享!!!
coolman_99
coolman_99 Lv.2
2008年03月24日 11:49:35
来自于学生专栏
Tall Building StructureAbstract: This article mainly analyzes the Tall Building Structures. Including Shear-Wall Systems, Rigid-Frame Systems, Tubular Systems. Through the analysis of the most common structure styles for the high-rise architecture. We conclude that during the design progress, the reasonable style should be adopted economically .
Key words: high-rise system load
⒈Introduction
Tall towers and buildings have fascinated mankind from the beginning of civilization ,their construction being initially for defense and sequently for ecclesiastical purposes. The growth in modern tall building construction,however,which began in the 1880s,has been largely for commercial and residential purposes,but it is difficult to define a Tall Building Structure. One may say that a low-rise building ranges from 1 to 2 or 3 stories. A medium-rise building probably ranges between 3 or 4 stories up to 10 or 20 stories. Thus a high–rise building is probably one that has at least some 10 stories or more.
Although the basic principal of vertical and horizontal subsystem design remain the same for low-, medium-or Tall Building Structure, when a building gets high the vertical subsystems become a controlling problem for two reasons. Higher vertical loads will require larger columns , walls, deflections produced by lateral forces are much larger and must be carefully provided for.
The vertical subsystems in a high–rise building transmit accumulated gravity load from story to story , thus requiring larger column or wall sections to support such loading. In addition, these same vertical subsystems must transmit lateral loads , such as wind or seismic loads ,to the foundations. However , in contrast to vertical load, lateral load effects on buildings are not linear and increase rapidly with increase in height. For example, inder wind load, the overturning moment at the base of building varies approximately as the square of the height of the building, and the lateral deflections at the top of a building may vary as the fourth power of building height, other things being equal. Earthquake produces an even more pronounced effect.
When the structure for a low –or medium –rise building is designed for dead and live load , it is almost an inherent property that the columns, walls, and stair or elevator shafts can carry most of the horizontal forces. The problem is primarily one of shear resistance. Moderate addition bracing for rigid frames in “short” buildings can easily be provided by filling certain panels (or even all panels)without increasing the sizes of the columns and girders otherwise required for vertical loads.
Unfortunately, this is not so for Tall Building Structures because the problem is primarily resistance to moment and deflection rather than shear alone. Special structural arrangements will often have to be made and additional structural material is always required for the columns, girders, walls, an slabs in order to make a Tall Building Structure sufficiently resistant to much higher lateral loads an deformations.
免费打赏
kililo2005
2008年06月05日 06:37:39
32楼
我有需要 真心感谢
我得邮箱kililo2005@163.com
chunmy54
2008年06月10日 01:09:49
33楼
楼主给我发下吧谢谢了呀 邮箱chunmy54@163.com
illidian110
2008年06月14日 14:51:11
34楼
楼主真是大好人啊,能给我来一篇吗,我的要求只要是与土木工程相关的3000字的中英文对照翻译即可,谢谢楼主!
wl0080203
2008年10月18日 12:10:04
35楼
wl0080203@163.com ding !!!
thanks
lihongbiao125
2008年10月28日 14:51:09
36楼
LZ能不能发个关于施工组织与投标书的外文翻译,2000字左右
邮箱:yxlin87@126.com
先谢谢啦~~
college12
2008年11月07日 13:04:30
37楼
谢谢啊,给我一份,最好要有出处,
college12@163.com
yuanhaiyan_1984
2008年12月23日 21:14:53
38楼
对我很帮助。谢谢楼主!看了很有启发,真是受益匪钱!谢谢!
xb05230214
2008年12月24日 22:56:44
39楼
辛苦了 谢谢大哥。。。。 398849202@163.com
xb05230214
2008年12月24日 22:59:54
40楼
顶一下:victory:
太感谢了
398849202@163.com
xb05230214
2008年12月24日 23:00:55
41楼
顶一下:victory:
太感谢了
398849202@163.com
