土木毕业设计外文翻译中英对照版~~吐血共享!!!
coolman_99
coolman_99 Lv.2
2008年03月24日 11:49:35
来自于学生专栏
Tall Building StructureAbstract: This article mainly analyzes the Tall Building Structures. Including Shear-Wall Systems, Rigid-Frame Systems, Tubular Systems. Through the analysis of the most common structure styles for the high-rise architecture. We conclude that during the design progress, the reasonable style should be adopted economically .
Key words: high-rise system load
⒈Introduction
Tall towers and buildings have fascinated mankind from the beginning of civilization ,their construction being initially for defense and sequently for ecclesiastical purposes. The growth in modern tall building construction,however,which began in the 1880s,has been largely for commercial and residential purposes,but it is difficult to define a Tall Building Structure. One may say that a low-rise building ranges from 1 to 2 or 3 stories. A medium-rise building probably ranges between 3 or 4 stories up to 10 or 20 stories. Thus a high–rise building is probably one that has at least some 10 stories or more.
Although the basic principal of vertical and horizontal subsystem design remain the same for low-, medium-or Tall Building Structure, when a building gets high the vertical subsystems become a controlling problem for two reasons. Higher vertical loads will require larger columns , walls, deflections produced by lateral forces are much larger and must be carefully provided for.
The vertical subsystems in a high–rise building transmit accumulated gravity load from story to story , thus requiring larger column or wall sections to support such loading. In addition, these same vertical subsystems must transmit lateral loads , such as wind or seismic loads ,to the foundations. However , in contrast to vertical load, lateral load effects on buildings are not linear and increase rapidly with increase in height. For example, inder wind load, the overturning moment at the base of building varies approximately as the square of the height of the building, and the lateral deflections at the top of a building may vary as the fourth power of building height, other things being equal. Earthquake produces an even more pronounced effect.
When the structure for a low –or medium –rise building is designed for dead and live load , it is almost an inherent property that the columns, walls, and stair or elevator shafts can carry most of the horizontal forces. The problem is primarily one of shear resistance. Moderate addition bracing for rigid frames in “short” buildings can easily be provided by filling certain panels (or even all panels)without increasing the sizes of the columns and girders otherwise required for vertical loads.
Unfortunately, this is not so for Tall Building Structures because the problem is primarily resistance to moment and deflection rather than shear alone. Special structural arrangements will often have to be made and additional structural material is always required for the columns, girders, walls, an slabs in order to make a Tall Building Structure sufficiently resistant to much higher lateral loads an deformations.
免费打赏
ly3323611
2008年05月06日 20:01:15
12楼
老大帮帮忙啊,谢谢了.
ly3323611@163.com
wstc1221
2008年05月08日 14:45:46
13楼
LZ可可不可以帮我找个1万字节的建筑外文啊?谢了啊
wstc1221
2008年05月08日 14:46:51
14楼
LZ可不可以帮我发个1万字节的建筑结构外文翻译啊?谢谢了,我的邮箱是wstc1221@163.com
yuan19850115
2008年05月08日 18:25:43
15楼
hao
songguannan1987
2008年05月09日 13:31:09
16楼
需要有作者和出处的 框架类 不少于10000外字符
songguannan1987@163.com
谢谢啊!!!
hot_118872394
2008年05月15日 10:36:55
17楼
太感谢了
hot_118872394@163.com
guyongkai
2008年05月16日 22:15:34
18楼
如果楼主看到的话’
也给我一份啊要有出处的谢谢啊
nbuguyongkai@126.com
alexwpc
2008年05月17日 11:04:06
19楼
顶一下
handi1986
2008年05月25日 09:27:12
20楼
如果楼主看到的话’
也给我一份啊要有出处的谢谢啊
fangzhigang85@163.com
jingyaorose
2008年05月25日 10:04:52
21楼
楼主真是大好人啊,能给我来一篇吗,我的要求只要是与土木工程相关的3000字的中英文对照翻译即可,谢谢楼主!
