土木毕业设计外文翻译中英对照版~~吐血共享!!!
coolman_99
coolman_99 Lv.2
2008年03月24日 11:49:35
来自于学生专栏
Tall Building StructureAbstract: This article mainly analyzes the Tall Building Structures. Including Shear-Wall Systems, Rigid-Frame Systems, Tubular Systems. Through the analysis of the most common structure styles for the high-rise architecture. We conclude that during the design progress, the reasonable style should be adopted economically .
Key words: high-rise system load
⒈Introduction
Tall towers and buildings have fascinated mankind from the beginning of civilization ,their construction being initially for defense and sequently for ecclesiastical purposes. The growth in modern tall building construction,however,which began in the 1880s,has been largely for commercial and residential purposes,but it is difficult to define a Tall Building Structure. One may say that a low-rise building ranges from 1 to 2 or 3 stories. A medium-rise building probably ranges between 3 or 4 stories up to 10 or 20 stories. Thus a high–rise building is probably one that has at least some 10 stories or more.
Although the basic principal of vertical and horizontal subsystem design remain the same for low-, medium-or Tall Building Structure, when a building gets high the vertical subsystems become a controlling problem for two reasons. Higher vertical loads will require larger columns , walls, deflections produced by lateral forces are much larger and must be carefully provided for.
The vertical subsystems in a high–rise building transmit accumulated gravity load from story to story , thus requiring larger column or wall sections to support such loading. In addition, these same vertical subsystems must transmit lateral loads , such as wind or seismic loads ,to the foundations. However , in contrast to vertical load, lateral load effects on buildings are not linear and increase rapidly with increase in height. For example, inder wind load, the overturning moment at the base of building varies approximately as the square of the height of the building, and the lateral deflections at the top of a building may vary as the fourth power of building height, other things being equal. Earthquake produces an even more pronounced effect.
When the structure for a low –or medium –rise building is designed for dead and live load , it is almost an inherent property that the columns, walls, and stair or elevator shafts can carry most of the horizontal forces. The problem is primarily one of shear resistance. Moderate addition bracing for rigid frames in “short” buildings can easily be provided by filling certain panels (or even all panels)without increasing the sizes of the columns and girders otherwise required for vertical loads.
Unfortunately, this is not so for Tall Building Structures because the problem is primarily resistance to moment and deflection rather than shear alone. Special structural arrangements will often have to be made and additional structural material is always required for the columns, girders, walls, an slabs in order to make a Tall Building Structure sufficiently resistant to much higher lateral loads an deformations.
免费打赏
zyl243409161
2011年03月08日 17:52:54
152楼
楼主是个大好人,发一份给我吧。邮箱 243409161@qq.com
dcsun1987
2011年03月09日 20:16:54
153楼
请问 如何下载啊
dcsun1987
2011年03月09日 20:18:48
154楼
我想要 645525864@qq.com 谢谢楼主了
lucyliu530
2011年03月24日 09:03:30
155楼
需要应对毕业设计的外文翻译!希望楼主能慷慨搭救!最好是关于公园设计的,或者相关设计的都行!实在是摆脱了!
605515002@qq.com
lovexiaobai
2011年03月26日 11:18:44
156楼
746768575@qq.com跪求啊!!!
liu122150
2012年03月21日 13:32:57
157楼
我也急需这个。谢谢啦。邮箱 liu122150@163.com
lx3913
2012年03月22日 22:22:38
158楼
直接发中文版的嘛,省得我翻译。、
qq_1427598874725
2015年03月29日 11:21:49
159楼
楼主好人!!!希望来一份中英文都有的!多谢多谢!急用! 509081940@qq.com
