Strucad10.1钢结构详图软件
gary2008
gary2008 Lv.3
2006年08月02日 10:45:42
INSTALL METHODThe first thing, before attempting to install the software, is to install the Sentinel Dongle Emulator following the instructions below:Sentinel Emulator Installation procedure.1. Double click the StruCAD.REG file which resides in the Crack folder. This adds a support for a key. You’ll get a window asking you for permission to add information to the registry. Answer "YES".
INSTALL METHOD
2. Then you need to install the Sentinel Emulator which again resides in the Crack folder as SentEmul.EXE. Double clicking on this file launches the Emulator programme.
3. Select destination directory and program group.
4. Select "Automatic Start" if you want to start driver instead of original sentinel driver and don’t use shortcuts to start driver.
5. Now reboot your computer.
Now you can install the software.
1. When asked if the programme should attempt to find a hardware lock, answer ‘No’.
2. Choose ‘Custom’ when asked for the type of installation and select all except StruCam.
3. When asked for the dongle code, use the following key: 46111113922222/4369 and click ‘Compile’
4. When asked if you want to install Microsoft.net frame, click ‘yes’
5. Reboot your computer again.
Finally, when you attempt do anything inside the programme, for the first time only, you will be asked for a password, use 45205903611719 for Strucad v10.1.
SETUP WEB:http://co.163.com/forum/content/1654_365569_1.htm
5a0174b2193c751acd0b.rar
215 KB
立即下载
免费打赏
toversteel
2006年08月04日 10:18:30
12楼
输入锁号46111113922222/4369,单击编译Compile,提示出错!哪位能解惑!?
shijie172
2006年08月04日 12:06:52
13楼
我今天高兴了半天,等下载安装到最后,我输入锁号46111113922222/4369,单击编译Compile,,老是报错,求求各位能帮我解释一下么?非常感谢!
liulh87
2006年08月04日 17:43:50
14楼
你们跟我可能犯了一样的错误,下安装了软件。
我在另外一台电脑上试,按二楼方法。可以。可是原来的电脑不可以,因为不知道怎么卸载。
liulh87
2006年08月04日 17:45:30
15楼
你们跟我可能犯了一样的错误,先安装了软件。
可是原来的电脑不可以,因为不知道怎么卸载这个软件。
wwwjjj2005
2006年08月06日 21:22:43
16楼
谢谢,按照10楼的办法,终于安装成功了,还是中文版的
harve
2006年08月08日 20:01:34
17楼
我也装上了,可怎么好象不能显示实体模型啊???求高手指教!!!
zhaokemeng
2006年11月05日 14:48:01
18楼
真能用吗?
twtvfhp11
2006年11月07日 14:54:06
19楼
有没人真的安装成功了啊
e-start
2006年11月09日 21:32:36
20楼
哪位大哥能不能上传个XSTEEL的破戒啊??????
billow2004
2006年12月22日 14:17:19
21楼
楼上的朋友,可能是求婚心急——虽然只准备给他心爱的人一个破戒指,但苦于没有现成的,一时着急求大家给他上传一个,大家帮帮他吧!加油!
