阀门danfoss,所有的消防管道和空调水系统管道为无缝钢管,消防管道经过喷砂处理后热镀锌成型,现场滚槽卡箍连接,小管径管道用国内新奇五金支架,大管道为热镀锌后的槽钢或工字钢支架,室外管道使用喜利得管道。风管管道支架系统与水系统一样,支架与风管之间用25mm的木衬垫。风管等级为630mm,0.8mm厚,1000mm,1.0mm;1500mm,1.2mm厚。
12楼
Installed Liebert Hiross split units
13楼
AHU: Robatherm made in Germany.
Split unit: liebert Hiross made in Italy.
Outdoor support: Hilti made in Germany.
Fancoils:Carrier made in USA.
Balancing valve: TA
Steam valve: Spirax Sarco made in UK.
Fan: Airflow made in Zhenjiang
Water valve: Danfoss made in France
HVAC control system: Siemens
Firefighting alarm system:siemens.
Waste water pump:Grundfos made in Germany, ARGAL made in Austria
Storm water system: Geberit.
Fire damper: Trox
Volume damper: Wysermann.
Air raising equipment:HYDROSYS INDUSTRIES made in Singapore
Textile duct(Fiber duct): Dokee made in USA.
Fancoils control panel: M’c quary made in China.
14楼
全貌
15楼
用镀锌槽钢? 嗷嗷的~~
16楼
有钱了就是牛
17楼
看来不论是设备,还是主材都是优质的啊!造价估计会很高的!
18楼
真厉害啊!
19楼
支吊架均为预制成品,牛!
20楼
4楼的风管托架不错呀!!!!!!!
值得学习
11楼的过滤器是不是装翻了呀?
大家看看(0-0)
21楼
兄弟是什么单位的,这个案例可能是典型的德国企业样板,苏州园区的某德资也是,阀门基本全是danfoss,主机和空调箱是Carrier,trane,水泵全是威乐(配ABB马达),冷却塔是马利,BAS控制系统是自己做的(其集团内部有自动控制系统业务)PLC控制,自控元件除PLC和变频器外全是siemens(valve and sensor),恒温恒湿机也是Hiross,管道的施工方式和这个一样,热水锅炉是菲斯曼的,燃烧机是威索,唉,实在是豪华啊。。。。。。刚到这个单位上班的时候真是震惊。。。有钱就是不一样。。。
