DIALux 主页 http://www.dialux.com 中文4.2版下载地址 http://www.dial.de/download/DIALuxSetup4200.exe个人感觉是所有照明计算软件里最容易掌握的计算软件,软件升级也很快,而且是免费下载。该软件主要用途是用于计算,它出的报表会让工作量减少很多。很适合作实际项目的专业人士使用。 动画版教程 http://co.163.com/neteaseivp/resource/software/detail.jsp?pk=71326&way=3
学会这个之后,一分钟就能计算出简单布置的灯具照度。
DIALux教程-室内篇 http://co.163.com/r/c3/3_1122094546230_0_0.htm?way=3
这个是升级课程,掌握起来需要多一些时间,呵呵。
72楼
新版本发布了,4.1.0.3版,作出了不少方便使用的更改:
Dear DIALux user,
Yet again we have some interesting and important news for you:
New DIALux Version 4.1.0.3
For a few weeks the new version 4.1.03 has been available as a download under www.DIAL.de and www.dialux.com . For this version we were again able to make a few small improvements. The most substantial modification made was to remedy an error which occurred every now and again when saving projects. In rare cases it was not possible to load the projects again. Usually it was then only possible
to load backup data ( the same file name as the DIALux project file but with the ending .bak instead of .dlx). In some rare cases not only DLX but also BAK files were affected. With the new 4.1.0.3 version we have managed to remedy this error.
A further improvement has been made to the printout. As a user you have the option of defining the number of grid points for tables and isolines etc. in the printout. Since the calculation is much finer and uses a grid with varying intervals, sometimes, because of the interpolation, a minimum or maximum value appeared which could not be found in the table. A modification in the output now
ensures that the minimum and maximum values always refer to the grid selected and correspond to the user settings.
We would recommend that you install the 4.1.0.3 version. If you want to check that you have installed the latest version, you simply click on online Update in the menu DIALux then checks via the Internet if a new version is available. You can also see the number of the version installed by clicking on info about DIALux?in the menu.
New project partners
Today we are also able to introduce new DIALux project partners: Luxonic (England), Indalux (Spain) and Exporlux (Portugal). The electronic catalogues of our new partners will be available shortly as offline and online plugIns.
You can download DIALux free of charge under www.dialux.com . On our website you will also find further useful tips concerning DIALux, lighting design and building technology.
Best wishes from Ludenscheid
Your DIALux Team
73楼
非常感謝版主!我的室內設計師,案子:一間辦公室(如圖),中間筒燈和石英射燈,天花設計有向三面牆照的燈帶。
問題在燈帶上,它是間接照明,是否應減小光通量?按照什麼數據減?
74楼
还是有些不会用.
75楼
这种间接照明按照灯槽的形状、尺寸、材料的不同,我会根据经验打0.1--0.2的修正系数
就是说80%~90% OFF
76楼
well
77楼
各位大哥:
我下載不了呀?
我公司的系統是繁體版,POPO安了會亂碼呀。
可否請哪位大俠給我傳一份动画版教程呀?
loneczf@@126.com , 謝謝!
QQ:349465035,希望能和各位大俠們多交流!
78楼
各位大哥好
我是刚入电气行业的新手,虽然以前是学电子的,可是毕业一直没做对口的工作,所以现在觉得什么都不懂,特别是算照度啊,什么的,都不知如何算的,也不知安装方式
有没有哪位好心的大哥帮帮我啊,
79楼
照明工程师: 我在安装的时候出现 The installation wizard could not determin the correct Microsoft MDAC version on this computer.
Currently version 2.50.4403.12 is installed on this computer, but version 2.70.0.0 is at least expacted.
Please install a suitable version or contact the DIALux Hotline.
怎么办?
80楼
楼上兄弟缺少一个MDAC的驱动,就在下载页面可以得到:
下载地址 http://www.nvc-lighting.com.cn/zhishi_detail.asp?id=313 (请留意页面说明)
81楼
谢谢,软件下载了,使用很方便。
